Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
https://www.audacityteam.org/download/).
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Sat Oct 15, 2016 12:25 pm
monnerat wrote:I found the solution:
Gnome2 accessibility is enabled and this requires libgail-gnome which is not available anymore
This occurs even if audacity is compiled with wxGTK3.
To disable gnome2 accessibility, use the command:
Code: Select all
gconftool-2 --set /desktop/gnome/interface/accessibility --type bool false
After that, audacity starts properly again
Thanks for posting.
So if you run that command, even the Fedora-packaged version of Audacity launches, and so it is a packaging problem?
The current Audacity 2.1.2 source code requires wxGTK 3.0.x, preferably 3.0.2. If you compile wxWidgets yourself it should be built with the default gtk2 option, not with gtk3.
blackhawk60
Post
by blackhawk60 » Sat Jan 11, 2020 5:12 pm
Thanks for this thread! I have/had the same issue on Xubuntu 19.10 and Audacity 2.3.2.
- Site Admin
Post
by steve » Sat Jan 11, 2020 5:17 pm
blackhawk60 wrote: ↑Sat Jan 11, 2020 5:12 pm
Did this (very old) thread allow you to resolve the issue? If so, what exactly did you do to fix the problem?
