I recorded a voice over which sounds okay through a variety of software.
However, audacity (2.1.2) on Ubuntu 15.04 gives me an awful crackling, clicking, popping, like it is playing antique vinyl.
Any clue?
(Running Ubuntu 15.04, Audacity 2.1.2)
Audacity playback gives static crackling? [SOLVED]
Please state:
Please state:
- Quality Assurance
Re: Audacity playback gives static crackling?
if you are using the "pulse" or "default" playback device in Audacity's Device Toolbar, please see
http://wiki.audacityteam.org/wiki/Linux_Issues#pulse.
Had already applied that setting to keep Audacity from playing too fast.Gale Andrews wrote:if you are using the "pulse" or "default" playback device in Audacity's Device Toolbar, please see
Anyways, switching to HDA Intel PCH: ALC fixed my problem.
Thanks!
- Quality Assurance
Re: Audacity playback gives static crackling? [SOLVED]
Good. It is always best to say what fixes you have already tried when you post.eezacque wrote:Had already applied that setting to keep Audacity from playing too fast.Gale Andrews wrote:if you are using the "pulse" or "default" playback device in Audacity's Device Toolbar, please see
Topic marked [SOLVED].
