onraad wrote:According to the Audio Device Info, you don't have any built-in audio device except HDMI.
Explain me why Audicty is playing for a while and then crashes.
Does it freeze so you have to force quit it, or crash (it simply disappears)?
If it freezes, see
http://wiki.audacityteam.org/wiki/Linux_Issues#pulse.
If it crashes, we still don't know what this Audacity 2.1.2 is and how exactly you chose it. In an English build of Ubuntu 14.04 you would not by default be able to obtain 2.1.2 from Synaptic.
If it is the daily build it is inherently unstable. You should not use daily builds unless you are a developer or software tester.
What does Help > About Audacity... say exactly for Audacity version number? On the "Build Information" tab of About Audacity, what is the program build date (near the bottom)?
onraad wrote:When you double-click that "Vous permettez" song, and so I assume it opens in Rhythmbox, how do you physically listen to the song?
Through an amplifier
How exactly does that "amplifier" connect to the computer? Through the HDMI output? Through an output with a headphones symbol?
onraad wrote:Are you using the USB cable to connect the turntable to the computer? If not, try doing that, then restart Audacity. Select the USB audio CODEC explicitly as the Recording Device in Device Toolbar.
I did all the time.
The USB audio CODEC does not show in your Audio Device Info so you could not select it. According to that Info, you have chosen the "default" recording and playback devices. Those devices are whatever pulseaudio (the Ubuntu sound mixer) is configured to use.
In a terminal, type:
Then
to open pavucontrol. You can then choose the recording (input) and playback (output) devices that pulse will use and which Audacity will use if you select "default" devices in Device Toolbar.
In your Audio Device Info I see some external device called "HD-Audio Generic: ALC269VC Analog (hw:2,0)". Is that actually the USB turntable? To test that, disconnect the USB turntable from the computer, restart Audacity, and see if that "HD-Audio Generic: ALC269VC Analog (hw:2,0)" device is still in Device Toolbar.
If "HD-Audio Generic: ALC269VC Analog (hw:2,0)" is still in Device Toolbar, what is that device? Is it an external sound card?
