Possible to automate MS mic decoding in Audacity?
Please state:
Re: Possible to automate MS mic decoding in Audacity?
Post by steve » Mon Feb 22, 2016 8:29 am
Bucky Ball wrote:Is there a way I can see exactly what the default MS Decode is doing, the steps it is taking to come up with the final stereo track? Just curious ... :-k
If I recall correctly, if you run the effect using the "Debug" button, then the exact settings used are displayed in a "debug window" that pops up when the processing is complete. That will give you a starting point for manually tweaking the mix. Note that you can increase the preview length in Audacity's preferences: http://manual.audacityteam.org/o/man/pl ... ences.html
jordancaver123
Operating System: Windows 7
Post by jordancaver123 » Sat May 19, 2018 9:24 am
thanks
