Building Audacity 2.1.2 on Debian unstable
Please state:
Witiko
Operating System: OS X 10.7 - 10.8 Lion / Mountain Lion
Post by Witiko » Tue Feb 16, 2016 12:48 am
I'm unsuccessfully trying to build version 2.1.2 of Audacity on Debian unstable.
Code: Select all
$ uname -a
Linux witiko 4.3.0-1-amd64 #1 SMP Debian 4.3.5-1 (2016-02-06) x86_64 GNU/Linux
This is how I proceed:
Code: Select all
# Get the Audacity repository.
$ git clone https://github.com/audacity/audacity
$ cd audacity
$ git checkout Audacity-2.1.2
# Install the dependencies
$ sudo apt install cmake automake autoconf
# Get the wxWidgets repository and build the library.
$ git clone https://github.com/wxWidgets/wxWidgets
$ cd wxWidgets
$ git checkout v3.0.2
$ ./configure && make
$ cd ..
# Build Audacity.
$ ./configure WX_CONFIG="$PWD"/wxWidgets/wx-config 2>&1 | tee ~/configure-53b8fd5.log
$ make 2>&1 | tee ~/make-53b8fd5.log
However, the compilation fails at linkage:
Code: Select all
$ tail -n12 make-53b8fd5.log
/bin/bash ../libtool  --tag=CXX   --mode=link g++ -Wno-unused-local-typedefs -I../lib-src/portmixer/include  -DwxDEBUG_LEVEL=0  -Wall -I../include -I../lib-src/FileDialog                   -rdynamic  -o audacity audacity-BlockFile.o audacity-DirManager.o audacity-Dither.o audacity-FileFormats.o audacity-Internat.o audacity-Prefs.o audacity-SampleFormat.o audacity-Sequence.o blockfile/audacity-LegacyAliasBlockFile.o blockfile/audacity-LegacyBlockFile.o blockfile/audacity-ODDecodeBlockFile.o blockfile/audacity-ODPCMAliasBlockFile.o blockfile/audacity-PCMAliasBlockFile.o blockfile/audacity-SilentBlockFile.o blockfile/audacity-SimpleBlockFile.o xml/audacity-XMLTagHandler.o audacity-AboutDialog.o audacity-AColor.o audacity-AudacityApp.o audacity-AudacityLogger.o audacity-AudioIO.o audacity-AutoRecovery.o audacity-BatchCommandDialog.o audacity-BatchCommands.o audacity-BatchProcessDialog.o audacity-Benchmark.o audacity-Dependencies.o audacity-DeviceChange.o audacity-DeviceManager.o audacity-Diags.o audacity-Envelope.o audacity-FFmpeg.o audacity-FFT.o audacity-FileIO.o audacity-FileNames.o audacity-FreqWindow.o audacity-HelpText.o audacity-HistoryWindow.o audacity-ImageManipulation.o audacity-InterpolateAudio.o audacity-LabelDialog.o audacity-LabelTrack.o audacity-LangChoice.o audacity-Languages.o audacity-Legacy.o audacity-Lyrics.o audacity-LyricsWindow.o audacity-Matrix.o audacity-Menus.o audacity-Mix.o audacity-MixerBoard.o audacity-ModuleManager.o audacity-PitchName.o audacity-PlatformCompatibility.o audacity-PluginManager.o audacity-Printing.o audacity-Profiler.o audacity-Project.o audacity-RealFFTf.o audacity-RealFFTf48x.o audacity-Resample.o audacity-RingBuffer.o audacity-Screenshot.o audacity-SelectedRegion.o audacity-Shuttle.o audacity-ShuttleGui.o audacity-ShuttlePrefs.o audacity-Snap.o audacity-SoundActivatedRecord.o audacity-Spectrum.o audacity-SplashDialog.o audacity-SseMathFuncs.o audacity-Tags.o audacity-Theme.o audacity-TimeDialog.o audacity-TimerRecordDialog.o audacity-TimeTrack.o audacity-Track.o audacity-TrackArtist.o audacity-TrackPanel.o audacity-TrackPanelAx.o audacity-UndoManager.o audacity-ViewInfo.o audacity-VoiceKey.o audacity-WaveClip.o audacity-WaveTrack.o audacity-WrappedType.o commands/audacity-AppCommandEvent.o commands/audacity-BatchEvalCommand.o commands/audacity-Command.o commands/audacity-CommandBuilder.o commands/audacity-CommandDirectory.o commands/audacity-CommandHandler.o commands/audacity-CommandManager.o commands/audacity-CommandSignature.o commands/audacity-CommandType.o commands/audacity-CompareAudioCommand.o commands/audacity-ExecMenuCommand.o commands/audacity-GetAllMenuCommands.o commands/audacity-GetProjectInfoCommand.o commands/audacity-GetTrackInfoCommand.o commands/audacity-HelpCommand.o commands/audacity-ImportExportCommands.o commands/audacity-Keyboard.o commands/audacity-MessageCommand.o commands/audacity-OpenSaveCommands.o commands/audacity-PreferenceCommands.o commands/audacity-ResponseQueue.o commands/audacity-ScreenshotCommand.o commands/audacity-ScriptCommandRelay.o commands/audacity-SelectCommand.o commands/audacity-SetProjectInfoCommand.o commands/audacity-SetTrackInfoCommand.o effects/audacity-Amplify.o effects/audacity-AutoDuck.o effects/audacity-BassTreble.o effects/audacity-Biquad.o effects/audacity-ChangePitch.o effects/audacity-ChangeSpeed.o effects/audacity-ChangeTempo.o effects/audacity-ClickRemoval.o effects/audacity-Compressor.o effects/audacity-Contrast.o effects/audacity-DtmfGen.o effects/audacity-Echo.o effects/audacity-Effect.o effects/audacity-EffectManager.o effects/audacity-EffectRack.o effects/audacity-Equalization.o effects/audacity-Equalization48x.o effects/audacity-Fade.o effects/audacity-FindClipping.o effects/audacity-Generator.o effects/audacity-Invert.o effects/audacity-Leveller.o effects/audacity-LoadEffects.o effects/audacity-Noise.o effects/audacity-NoiseReduction.o effects/audacity-NoiseRemoval.o effects/audacity-Normalize.o effects/audacity-Paulstretch.o effects/audacity-Phaser.o effects/audacity-Repair.o effects/audacity-Repeat.o effects/audacity-Reverb.o effects/audacity-Reverse.o effects/audacity-SBSMSEffect.o effects/audacity-ScienFilter.o effects/audacity-Silence.o effects/audacity-SimpleMono.o effects/audacity-SoundTouchEffect.o effects/audacity-StereoToMono.o effects/audacity-TimeScale.o effects/audacity-TimeWarper.o effects/audacity-ToneGen.o effects/audacity-TruncSilence.o effects/audacity-TwoPassSimpleMono.o effects/audacity-Wahwah.o export/audacity-Export.o export/audacity-ExportCL.o export/audacity-ExportFLAC.o export/audacity-ExportMP2.o export/audacity-ExportMP3.o export/audacity-ExportMultiple.o export/audacity-ExportOGG.o export/audacity-ExportPCM.o import/audacity-Import.o import/audacity-ImportFLAC.o import/audacity-ImportLOF.o import/audacity-ImportMP3.o import/audacity-ImportOGG.o import/audacity-ImportPCM.o import/audacity-ImportRaw.o import/audacity-RawAudioGuess.o import/audacity-FormatClassifier.o import/audacity-MultiFormatReader.o import/audacity-SpecPowerMeter.o ondemand/audacity-ODComputeSummaryTask.o ondemand/audacity-ODDecodeFFmpegTask.o ondemand/audacity-ODDecodeTask.o ondemand/audacity-ODManager.o ondemand/audacity-ODTask.o ondemand/audacity-ODTaskThread.o ondemand/audacity-ODWaveTrackTaskQueue.o prefs/audacity-BatchPrefs.o prefs/audacity-DevicePrefs.o prefs/audacity-DirectoriesPrefs.o prefs/audacity-EffectsPrefs.o prefs/audacity-ExtImportPrefs.o prefs/audacity-GUIPrefs.o prefs/audacity-ImportExportPrefs.o prefs/audacity-KeyConfigPrefs.o prefs/audacity-LibraryPrefs.o prefs/audacity-MidiIOPrefs.o prefs/audacity-ModulePrefs.o prefs/audacity-MousePrefs.o prefs/audacity-PlaybackPrefs.o prefs/audacity-PrefsDialog.o prefs/audacity-ProjectsPrefs.o prefs/audacity-QualityPrefs.o prefs/audacity-RecordingPrefs.o prefs/audacity-SpectrogramSettings.o prefs/audacity-SpectrumPrefs.o prefs/audacity-ThemePrefs.o prefs/audacity-TracksPrefs.o prefs/audacity-WarningsPrefs.o prefs/audacity-WaveformPrefs.o prefs/audacity-WaveformSettings.o toolbars/audacity-ControlToolBar.o toolbars/audacity-DeviceToolBar.o toolbars/audacity-EditToolBar.o toolbars/audacity-MeterToolBar.o toolbars/audacity-MixerToolBar.o toolbars/audacity-SelectionBar.o toolbars/audacity-SpectralSelectionBar.o toolbars/audacity-ToolBar.o toolbars/audacity-ToolDock.o toolbars/audacity-ToolManager.o toolbars/audacity-ToolsToolBar.o toolbars/audacity-TranscriptionToolBar.o widgets/audacity-AButton.o widgets/audacity-ASlider.o widgets/audacity-AttachableScrollBar.o widgets/audacity-ErrorDialog.o widgets/audacity-ExpandingToolBar.o widgets/audacity-FileHistory.o widgets/audacity-Grabber.o widgets/audacity-Grid.o widgets/audacity-HelpSystem.o widgets/audacity-HtmlWindow.o widgets/audacity-ImageRoll.o widgets/audacity-KeyView.o widgets/audacity-LinkingHtmlWindow.o widgets/audacity-Meter.o widgets/audacity-MultiDialog.o widgets/audacity-NumericTextCtrl.o widgets/audacity-numformatter.o widgets/audacity-ProgressDialog.o widgets/audacity-Ruler.o widgets/audacity-valnum.o widgets/audacity-Warning.o xml/audacity-XMLFileReader.o xml/audacity-XMLWriter.o  export/audacity-ExportFFmpeg.o export/audacity-ExportFFmpegDialogs.o import/audacity-ImportFFmpeg.o  effects/ladspa/audacity-LadspaEffect.o ondemand/audacity-ODDecodeFlacTask.o effects/nyquist/audacity-LoadNyquist.o effects/nyquist/audacity-Nyquist.o effects/lv2/audacity-LoadLV2.o effects/lv2/audacity-LV2Effect.o audacity-NoteTrack.o import/audacity-ImportMIDI.o  effects/vamp/audacity-LoadVamp.o effects/vamp/audacity-VampEffect.o effects/VST/audacity-VSTEffect.o effects/VST/audacity-VSTControlGTK.o -lexpat ../lib-src/FileDialog/libFileDialog.la -lportaudio -lasound -lm -lpthread ../lib-src/portmixer/src/libportmixer.la -lsndfile -lsoxr ../lib-src/lib-widget-extra/libwidgetextra.la -L/home/witiko/programs/audacity/wxWidgets/lib -pthread   -Wl,-rpath,/home/witiko/programs/audacity/wxWidgets/lib -lwx_gtk2u_xrc-3.0 -lwx_gtk2u_html-3.0 -lwx_gtk2u_qa-3.0 -lwx_gtk2u_adv-3.0 -lwx_gtk2u_core-3.0 -lwx_baseu_xml-3.0 -lwx_baseu_net-3.0 -lwx_baseu-3.0        -lFLAC++ -lFLAC -lid3tag -lz -lmad ../lib-src/libnyquist/libnyquist.a -lSoundTouch -ltwolame -lvorbisenc -lvorbisfile -lvorbis -logg ../lib-src/lv2/liblv2.a -lportSMF  -lsbsms -lvamp-hostsdk -ldl  -ldl   -lgtk-x11-2.0 -lgdk-x11-2.0 -lpangocairo-1.0 -latk-1.0 -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lpangoft2-1.0 -lpango-1.0 -lgobject-2.0 -lglib-2.0 -lfontconfig -lfreetype -lasound -ljack -lpthread -lrt -ludev
libtool: link: g++ -Wno-unused-local-typedefs -I../lib-src/portmixer/include -DwxDEBUG_LEVEL=0 -Wall -I../include -I../lib-src/FileDialog -rdynamic -o audacity audacity-BlockFile.o audacity-DirManager.o audacity-Dither.o audacity-FileFormats.o audacity-Internat.o audacity-Prefs.o audacity-SampleFormat.o audacity-Sequence.o blockfile/audacity-LegacyAliasBlockFile.o blockfile/audacity-LegacyBlockFile.o blockfile/audacity-ODDecodeBlockFile.o blockfile/audacity-ODPCMAliasBlockFile.o blockfile/audacity-PCMAliasBlockFile.o blockfile/audacity-SilentBlockFile.o blockfile/audacity-SimpleBlockFile.o xml/audacity-XMLTagHandler.o audacity-AboutDialog.o audacity-AColor.o audacity-AudacityApp.o audacity-AudacityLogger.o audacity-AudioIO.o audacity-AutoRecovery.o audacity-BatchCommandDialog.o audacity-BatchCommands.o audacity-BatchProcessDialog.o audacity-Benchmark.o audacity-Dependencies.o audacity-DeviceChange.o audacity-DeviceManager.o audacity-Diags.o audacity-Envelope.o audacity-FFmpeg.o audacity-FFT.o audacity-FileIO.o audacity-FileNames.o audacity-FreqWindow.o audacity-HelpText.o audacity-HistoryWindow.o audacity-ImageManipulation.o audacity-InterpolateAudio.o audacity-LabelDialog.o audacity-LabelTrack.o audacity-LangChoice.o audacity-Languages.o audacity-Legacy.o audacity-Lyrics.o audacity-LyricsWindow.o audacity-Matrix.o audacity-Menus.o audacity-Mix.o audacity-MixerBoard.o audacity-ModuleManager.o audacity-PitchName.o audacity-PlatformCompatibility.o audacity-PluginManager.o audacity-Printing.o audacity-Profiler.o audacity-Project.o audacity-RealFFTf.o audacity-RealFFTf48x.o audacity-Resample.o audacity-RingBuffer.o audacity-Screenshot.o audacity-SelectedRegion.o audacity-Shuttle.o audacity-ShuttleGui.o audacity-ShuttlePrefs.o audacity-Snap.o audacity-SoundActivatedRecord.o audacity-Spectrum.o audacity-SplashDialog.o audacity-SseMathFuncs.o audacity-Tags.o audacity-Theme.o audacity-TimeDialog.o audacity-TimerRecordDialog.o audacity-TimeTrack.o audacity-Track.o audacity-TrackArtist.o audacity-TrackPanel.o audacity-TrackPanelAx.o audacity-UndoManager.o audacity-ViewInfo.o audacity-VoiceKey.o audacity-WaveClip.o audacity-WaveTrack.o audacity-WrappedType.o commands/audacity-AppCommandEvent.o commands/audacity-BatchEvalCommand.o commands/audacity-Command.o commands/audacity-CommandBuilder.o commands/audacity-CommandDirectory.o commands/audacity-CommandHandler.o commands/audacity-CommandManager.o commands/audacity-CommandSignature.o commands/audacity-CommandType.o commands/audacity-CompareAudioCommand.o commands/audacity-ExecMenuCommand.o commands/audacity-GetAllMenuCommands.o commands/audacity-GetProjectInfoCommand.o commands/audacity-GetTrackInfoCommand.o commands/audacity-HelpCommand.o commands/audacity-ImportExportCommands.o commands/audacity-Keyboard.o commands/audacity-MessageCommand.o commands/audacity-OpenSaveCommands.o commands/audacity-PreferenceCommands.o commands/audacity-ResponseQueue.o commands/audacity-ScreenshotCommand.o commands/audacity-ScriptCommandRelay.o commands/audacity-SelectCommand.o commands/audacity-SetProjectInfoCommand.o commands/audacity-SetTrackInfoCommand.o effects/audacity-Amplify.o effects/audacity-AutoDuck.o effects/audacity-BassTreble.o effects/audacity-Biquad.o effects/audacity-ChangePitch.o effects/audacity-ChangeSpeed.o effects/audacity-ChangeTempo.o effects/audacity-ClickRemoval.o effects/audacity-Compressor.o effects/audacity-Contrast.o effects/audacity-DtmfGen.o effects/audacity-Echo.o effects/audacity-Effect.o effects/audacity-EffectManager.o effects/audacity-EffectRack.o effects/audacity-Equalization.o effects/audacity-Equalization48x.o effects/audacity-Fade.o effects/audacity-FindClipping.o effects/audacity-Generator.o effects/audacity-Invert.o effects/audacity-Leveller.o effects/audacity-LoadEffects.o effects/audacity-Noise.o effects/audacity-NoiseReduction.o effects/audacity-NoiseRemoval.o effects/audacity-Normalize.o effects/audacity-Paulstretch.o effects/audacity-Phaser.o effects/audacity-Repair.o effects/audacity-Repeat.o effects/audacity-Reverb.o effects/audacity-Reverse.o effects/audacity-SBSMSEffect.o effects/audacity-ScienFilter.o effects/audacity-Silence.o effects/audacity-SimpleMono.o effects/audacity-SoundTouchEffect.o effects/audacity-StereoToMono.o effects/audacity-TimeScale.o effects/audacity-TimeWarper.o effects/audacity-ToneGen.o effects/audacity-TruncSilence.o effects/audacity-TwoPassSimpleMono.o effects/audacity-Wahwah.o export/audacity-Export.o export/audacity-ExportCL.o export/audacity-ExportFLAC.o export/audacity-ExportMP2.o export/audacity-ExportMP3.o export/audacity-ExportMultiple.o export/audacity-ExportOGG.o export/audacity-ExportPCM.o import/audacity-Import.o import/audacity-ImportFLAC.o import/audacity-ImportLOF.o import/audacity-ImportMP3.o import/audacity-ImportOGG.o import/audacity-ImportPCM.o import/audacity-ImportRaw.o import/audacity-RawAudioGuess.o import/audacity-FormatClassifier.o import/audacity-MultiFormatReader.o import/audacity-SpecPowerMeter.o ondemand/audacity-ODComputeSummaryTask.o ondemand/audacity-ODDecodeFFmpegTask.o ondemand/audacity-ODDecodeTask.o ondemand/audacity-ODManager.o ondemand/audacity-ODTask.o ondemand/audacity-ODTaskThread.o ondemand/audacity-ODWaveTrackTaskQueue.o prefs/audacity-BatchPrefs.o prefs/audacity-DevicePrefs.o prefs/audacity-DirectoriesPrefs.o prefs/audacity-EffectsPrefs.o prefs/audacity-ExtImportPrefs.o prefs/audacity-GUIPrefs.o prefs/audacity-ImportExportPrefs.o prefs/audacity-KeyConfigPrefs.o prefs/audacity-LibraryPrefs.o prefs/audacity-MidiIOPrefs.o prefs/audacity-ModulePrefs.o prefs/audacity-MousePrefs.o prefs/audacity-PlaybackPrefs.o prefs/audacity-PrefsDialog.o prefs/audacity-ProjectsPrefs.o prefs/audacity-QualityPrefs.o prefs/audacity-RecordingPrefs.o prefs/audacity-SpectrogramSettings.o prefs/audacity-SpectrumPrefs.o prefs/audacity-ThemePrefs.o prefs/audacity-TracksPrefs.o prefs/audacity-WarningsPrefs.o prefs/audacity-WaveformPrefs.o prefs/audacity-WaveformSettings.o toolbars/audacity-ControlToolBar.o toolbars/audacity-DeviceToolBar.o toolbars/audacity-EditToolBar.o toolbars/audacity-MeterToolBar.o toolbars/audacity-MixerToolBar.o toolbars/audacity-SelectionBar.o toolbars/audacity-SpectralSelectionBar.o toolbars/audacity-ToolBar.o toolbars/audacity-ToolDock.o toolbars/audacity-ToolManager.o toolbars/audacity-ToolsToolBar.o toolbars/audacity-TranscriptionToolBar.o widgets/audacity-AButton.o widgets/audacity-ASlider.o widgets/audacity-AttachableScrollBar.o widgets/audacity-ErrorDialog.o widgets/audacity-ExpandingToolBar.o widgets/audacity-FileHistory.o widgets/audacity-Grabber.o widgets/audacity-Grid.o widgets/audacity-HelpSystem.o widgets/audacity-HtmlWindow.o widgets/audacity-ImageRoll.o widgets/audacity-KeyView.o widgets/audacity-LinkingHtmlWindow.o widgets/audacity-Meter.o widgets/audacity-MultiDialog.o widgets/audacity-NumericTextCtrl.o widgets/audacity-numformatter.o widgets/audacity-ProgressDialog.o widgets/audacity-Ruler.o widgets/audacity-valnum.o widgets/audacity-Warning.o xml/audacity-XMLFileReader.o xml/audacity-XMLWriter.o export/audacity-ExportFFmpeg.o export/audacity-ExportFFmpegDialogs.o import/audacity-ImportFFmpeg.o effects/ladspa/audacity-LadspaEffect.o ondemand/audacity-ODDecodeFlacTask.o effects/nyquist/audacity-LoadNyquist.o effects/nyquist/audacity-Nyquist.o effects/lv2/audacity-LoadLV2.o effects/lv2/audacity-LV2Effect.o audacity-NoteTrack.o import/audacity-ImportMIDI.o effects/vamp/audacity-LoadVamp.o effects/vamp/audacity-VampEffect.o effects/VST/audacity-VSTEffect.o effects/VST/audacity-VSTControlGTK.o -pthread -Wl,-rpath -Wl,/home/witiko/programs/audacity/wxWidgets/lib  /usr/lib/x86_64-linux-gnu/libexpat.so ../lib-src/FileDialog/.libs/libFileDialog.a -lportaudio -lm ../lib-src/portmixer/src/.libs/libportmixer.a -lsndfile -lsoxr ../lib-src/lib-widget-extra/.libs/libwidgetextra.a -L/home/witiko/programs/audacity/wxWidgets/lib -lwx_gtk2u_xrc-3.0 -lwx_gtk2u_html-3.0 -lwx_gtk2u_qa-3.0 -lwx_gtk2u_adv-3.0 -lwx_gtk2u_core-3.0 -lwx_baseu_xml-3.0 -lwx_baseu_net-3.0 -lwx_baseu-3.0 -lFLAC++ -lFLAC /usr/lib/libid3tag.so -lz -lmad ../lib-src/libnyquist/libnyquist.a -lSoundTouch -ltwolame /usr/lib/x86_64-linux-gnu/libvorbisenc.so /usr/lib/x86_64-linux-gnu/libvorbisfile.so /usr/lib/x86_64-linux-gnu/libvorbis.so -logg ../lib-src/lv2/liblv2.a -lportSMF -lsbsms -lvamp-hostsdk -ldl -lgtk-x11-2.0 -lgdk-x11-2.0 -lpangocairo-1.0 -latk-1.0 -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lpangoft2-1.0 -lpango-1.0 -lgobject-2.0 -lglib-2.0 -lfontconfig /usr/lib/x86_64-linux-gnu/libfreetype.so -lasound -ljack -lpthread -lrt -ludev -pthread
g++: error: ../lib-src/portmixer/src/.libs/libportmixer.a: No such file or directory
g++: error: ../lib-src/lib-widget-extra/.libs/libwidgetextra.a: No such file or directory
Makefile:1959: recipe for target 'audacity' failed
make[2]: *** [audacity] Error 1
make[2]: Leaving directory '/home/witiko/programs/audacity/src'
Makefile:1355: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/home/witiko/programs/audacity/src'
Makefile:726: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
I'm not sure how libtool came up with the ../lib-src/*/.libs/*.a paths. This isn't fixed by `dad346e` (Fix build for Debian Stable), though:
Code: Select all
$ git clean -fd -e wxWidgets
$ git reset --hard dad346e
$ autoreconf --no-recursive -i
$ ./configure WX_CONFIG="$PWD"/wxWidgets/wx-config 2>&1 | tee ~/configure-dad346e.log
$ make 2>&1 | tee ~/make-dad346e.log
This fails in a similar fashion:
Code: Select all
$ tail -n12 make-dad346e.log
libtool: link: g++ -Wno-unused-local-typedefs -I../lib-src/portmixer/include -DwxDEBUG_LEVEL=0 -Wall -I../include -I../lib-src/FileDialog -rdynamic -o audacity audacity-BlockFile.o audacity-DirManager.o audacity-Dither.o audacity-FileFormats.o audacity-Internat.o audacity-Prefs.o audacity-SampleFormat.o audacity-Sequence.o blockfile/audacity-LegacyAliasBlockFile.o blockfile/audacity-LegacyBlockFile.o blockfile/audacity-ODDecodeBlockFile.o blockfile/audacity-ODPCMAliasBlockFile.o blockfile/audacity-PCMAliasBlockFile.o blockfile/audacity-SilentBlockFile.o blockfile/audacity-SimpleBlockFile.o xml/audacity-XMLTagHandler.o audacity-AboutDialog.o audacity-AColor.o audacity-AudacityApp.o audacity-AudacityLogger.o audacity-AudioIO.o audacity-AutoRecovery.o audacity-BatchCommandDialog.o audacity-BatchCommands.o audacity-BatchProcessDialog.o audacity-Benchmark.o audacity-Dependencies.o audacity-DeviceChange.o audacity-DeviceManager.o audacity-Diags.o audacity-Envelope.o audacity-FFmpeg.o audacity-FFT.o audacity-FileIO.o audacity-FileNames.o audacity-FreqWindow.o audacity-HelpText.o audacity-HistoryWindow.o audacity-ImageManipulation.o audacity-InterpolateAudio.o audacity-LabelDialog.o audacity-LabelTrack.o audacity-LangChoice.o audacity-Languages.o audacity-Legacy.o audacity-Lyrics.o audacity-LyricsWindow.o audacity-Matrix.o audacity-Menus.o audacity-Mix.o audacity-MixerBoard.o audacity-ModuleManager.o audacity-PitchName.o audacity-PlatformCompatibility.o audacity-PluginManager.o audacity-Printing.o audacity-Profiler.o audacity-Project.o audacity-RealFFTf.o audacity-RealFFTf48x.o audacity-Resample.o audacity-RingBuffer.o audacity-Screenshot.o audacity-SelectedRegion.o audacity-Shuttle.o audacity-ShuttleGui.o audacity-ShuttlePrefs.o audacity-Snap.o audacity-SoundActivatedRecord.o audacity-Spectrum.o audacity-SplashDialog.o audacity-SseMathFuncs.o audacity-Tags.o audacity-Theme.o audacity-TimeDialog.o audacity-TimerRecordDialog.o audacity-TimeTrack.o audacity-Track.o audacity-TrackArtist.o audacity-TrackPanel.o audacity-TrackPanelAx.o audacity-UndoManager.o audacity-ViewInfo.o audacity-VoiceKey.o audacity-WaveClip.o audacity-WaveTrack.o audacity-WrappedType.o commands/audacity-AppCommandEvent.o commands/audacity-BatchEvalCommand.o commands/audacity-Command.o commands/audacity-CommandBuilder.o commands/audacity-CommandDirectory.o commands/audacity-CommandHandler.o commands/audacity-CommandManager.o commands/audacity-CommandSignature.o commands/audacity-CommandType.o commands/audacity-CompareAudioCommand.o commands/audacity-ExecMenuCommand.o commands/audacity-GetAllMenuCommands.o commands/audacity-GetProjectInfoCommand.o commands/audacity-GetTrackInfoCommand.o commands/audacity-HelpCommand.o commands/audacity-ImportExportCommands.o commands/audacity-Keyboard.o commands/audacity-MessageCommand.o commands/audacity-OpenSaveCommands.o commands/audacity-PreferenceCommands.o commands/audacity-ResponseQueue.o commands/audacity-ScreenshotCommand.o commands/audacity-ScriptCommandRelay.o commands/audacity-SelectCommand.o commands/audacity-SetProjectInfoCommand.o commands/audacity-SetTrackInfoCommand.o effects/audacity-Amplify.o effects/audacity-AutoDuck.o effects/audacity-BassTreble.o effects/audacity-Biquad.o effects/audacity-ChangePitch.o effects/audacity-ChangeSpeed.o effects/audacity-ChangeTempo.o effects/audacity-ClickRemoval.o effects/audacity-Compressor.o effects/audacity-Contrast.o effects/audacity-DtmfGen.o effects/audacity-Echo.o effects/audacity-Effect.o effects/audacity-EffectManager.o effects/audacity-EffectRack.o effects/audacity-Equalization.o effects/audacity-Equalization48x.o effects/audacity-Fade.o effects/audacity-FindClipping.o effects/audacity-Generator.o effects/audacity-Invert.o effects/audacity-Leveller.o effects/audacity-LoadEffects.o effects/audacity-Noise.o effects/audacity-NoiseReduction.o effects/audacity-NoiseRemoval.o effects/audacity-Normalize.o effects/audacity-Paulstretch.o effects/audacity-Phaser.o effects/audacity-Repair.o effects/audacity-Repeat.o effects/audacity-Reverb.o effects/audacity-Reverse.o effects/audacity-SBSMSEffect.o effects/audacity-ScienFilter.o effects/audacity-Silence.o effects/audacity-SimpleMono.o effects/audacity-SoundTouchEffect.o effects/audacity-StereoToMono.o effects/audacity-TimeScale.o effects/audacity-TimeWarper.o effects/audacity-ToneGen.o effects/audacity-TruncSilence.o effects/audacity-TwoPassSimpleMono.o effects/audacity-Wahwah.o export/audacity-Export.o export/audacity-ExportCL.o export/audacity-ExportFLAC.o export/audacity-ExportMP2.o export/audacity-ExportMP3.o export/audacity-ExportMultiple.o export/audacity-ExportOGG.o export/audacity-ExportPCM.o import/audacity-Import.o import/audacity-ImportFLAC.o import/audacity-ImportLOF.o import/audacity-ImportMP3.o import/audacity-ImportOGG.o import/audacity-ImportPCM.o import/audacity-ImportRaw.o import/audacity-RawAudioGuess.o import/audacity-FormatClassifier.o import/audacity-MultiFormatReader.o import/audacity-SpecPowerMeter.o ondemand/audacity-ODComputeSummaryTask.o ondemand/audacity-ODDecodeFFmpegTask.o ondemand/audacity-ODDecodeTask.o ondemand/audacity-ODManager.o ondemand/audacity-ODTask.o ondemand/audacity-ODTaskThread.o ondemand/audacity-ODWaveTrackTaskQueue.o prefs/audacity-BatchPrefs.o prefs/audacity-DevicePrefs.o prefs/audacity-DirectoriesPrefs.o prefs/audacity-EffectsPrefs.o prefs/audacity-ExtImportPrefs.o prefs/audacity-GUIPrefs.o prefs/audacity-ImportExportPrefs.o prefs/audacity-KeyConfigPrefs.o prefs/audacity-LibraryPrefs.o prefs/audacity-MidiIOPrefs.o prefs/audacity-ModulePrefs.o prefs/audacity-MousePrefs.o prefs/audacity-PlaybackPrefs.o prefs/audacity-PrefsDialog.o prefs/audacity-ProjectsPrefs.o prefs/audacity-QualityPrefs.o prefs/audacity-RecordingPrefs.o prefs/audacity-SpectrogramSettings.o prefs/audacity-SpectrumPrefs.o prefs/audacity-ThemePrefs.o prefs/audacity-TracksPrefs.o prefs/audacity-WarningsPrefs.o prefs/audacity-WaveformPrefs.o prefs/audacity-WaveformSettings.o toolbars/audacity-ControlToolBar.o toolbars/audacity-DeviceToolBar.o toolbars/audacity-EditToolBar.o toolbars/audacity-MeterToolBar.o toolbars/audacity-MixerToolBar.o toolbars/audacity-SelectionBar.o toolbars/audacity-SpectralSelectionBar.o toolbars/audacity-ToolBar.o toolbars/audacity-ToolDock.o toolbars/audacity-ToolManager.o toolbars/audacity-ToolsToolBar.o toolbars/audacity-TranscriptionToolBar.o widgets/audacity-AButton.o widgets/audacity-ASlider.o widgets/audacity-AttachableScrollBar.o widgets/audacity-ErrorDialog.o widgets/audacity-ExpandingToolBar.o widgets/audacity-FileHistory.o widgets/audacity-Grabber.o widgets/audacity-Grid.o widgets/audacity-HelpSystem.o widgets/audacity-HtmlWindow.o widgets/audacity-ImageRoll.o widgets/audacity-KeyView.o widgets/audacity-LinkingHtmlWindow.o widgets/audacity-Meter.o widgets/audacity-MultiDialog.o widgets/audacity-NumericTextCtrl.o widgets/audacity-numformatter.o widgets/audacity-ProgressDialog.o widgets/audacity-Ruler.o widgets/audacity-valnum.o widgets/audacity-Warning.o xml/audacity-XMLFileReader.o xml/audacity-XMLWriter.o export/audacity-ExportFFmpeg.o export/audacity-ExportFFmpegDialogs.o import/audacity-ImportFFmpeg.o effects/ladspa/audacity-LadspaEffect.o ondemand/audacity-ODDecodeFlacTask.o effects/nyquist/audacity-LoadNyquist.o effects/nyquist/audacity-Nyquist.o effects/lv2/audacity-LoadLV2.o effects/lv2/audacity-LV2Effect.o audacity-NoteTrack.o import/audacity-ImportMIDI.o effects/vamp/audacity-LoadVamp.o effects/vamp/audacity-VampEffect.o effects/VST/audacity-VSTEffect.o effects/VST/audacity-VSTControlGTK.o -pthread -Wl,-rpath -Wl,/home/witiko/programs/audacity/wxWidgets/lib  /usr/lib/x86_64-linux-gnu/libexpat.so ../lib-src/FileDialog/.libs/libFileDialog.a -lportaudio -lm ../lib-src/portmixer/src/.libs/libportmixer.a -lsndfile -lsoxr ../lib-src/lib-widget-extra/.libs/libwidgetextra.a -L/home/witiko/programs/audacity/wxWidgets/lib -lwx_gtk2u_xrc-3.0 -lwx_gtk2u_html-3.0 -lwx_gtk2u_qa-3.0 -lwx_gtk2u_adv-3.0 -lwx_gtk2u_core-3.0 -lwx_baseu_xml-3.0 -lwx_baseu_net-3.0 -lwx_baseu-3.0 -lFLAC++ -lFLAC /usr/lib/libid3tag.so -lz -lmad ../lib-src/libnyquist/libnyquist.a -lSoundTouch -ltwolame /usr/lib/x86_64-linux-gnu/libvorbisenc.so /usr/lib/x86_64-linux-gnu/libvorbisfile.so /usr/lib/x86_64-linux-gnu/libvorbis.so -logg ../lib-src/lv2/liblv2.a -lportSMF ../lib-src/sbsms/src/.libs/libsbsms.a -lvamp-hostsdk -ldl -lgtk-x11-2.0 -lgdk-x11-2.0 -lpangocairo-1.0 -latk-1.0 -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lpangoft2-1.0 -lpango-1.0 -lgobject-2.0 -lglib-2.0 -lfontconfig /usr/lib/x86_64-linux-gnu/libfreetype.so -lasound -ljack -lpthread -lrt -ludev -pthread
g++: error: ../lib-src/sbsms/src/.libs/libsbsms.a: No such file or directory
Makefile:1963: recipe for target 'audacity' failed
Makefile:1359: recipe for target 'all' failed
Makefile:805: recipe for target 'all-recursive' failed
I'm curious, if there is some obvious mistake I'm making here. I did consult the available documentation [1,2], but that didn't shed any light on the matter for me. I will be grateful for any pointers before I bury deep into the innards of Audacity. :)
(44.88 KiB) Downloaded 42 times
make-53b8fd5.log
(724.93 KiB) Downloaded 42 times
(50.23 KiB) Downloaded 44 times
make-dad346e.log
(696.58 KiB) Downloaded 42 times
Re: Building Audacity 2.1.2 on Debian unstable
Post by Gale Andrews » Wed Feb 17, 2016 12:16 pm
Have you tried
Code: Select all
sudo apt-get build-dep audacity
instead of "sudo apt install cmake automake autoconf".
Witiko
Post by Witiko » Sun Feb 28, 2016 3:11 pm
I did now, but the results are identical. I appologize about the late reply, I did not subscribe the thread, although I thought I did, so I wasn't notified about your response.
Post by Gale Andrews » Sun Feb 28, 2016 3:32 pm
You could install your local copy of wxWidgets then run
Code: Select all
sudo ldconfig
This would be normal practice in my book anyway. The default installation of wxWidgets is to /usr/local/ so it should not mess up apps that use system wxWidgets.
In any case you can configure with
Code: Select all
--prefix=
if you want a custom installation directory.
Witiko
Post by Witiko » Sun Feb 28, 2016 4:53 pm
I ran
Code: Select all
sudo make install && sudo ldconfig
in the the wxWidgets directory, then I reran
Code: Select all
git clean -f && ./configure && make
within the audacity directory, but the result was the same as before when running
Code: Select all
Post by Gale Andrews » Mon Feb 29, 2016 12:25 pm
The /lib-src/portmixer/src/.libs/ folder should be there when building.
Have you tried the recommended
Code: Select all
mkdir build
Code: Select all
cd build
Code: Select all
../configure --disable-dynamic-loading
so you don't contaminate the source tree with the build files and folders, and so it is easier to build with ffmpeg?
Witiko
Post by Witiko » Mon Feb 29, 2016 3:04 pm
Gale Andrews wrote:The /lib-src/portmixer/src/.libs/ folder should be there when building.
I just realized that (since there are other other /lib-src/*/src/.libs/) and I'm making some progress here. Specifically, I entered each of the /lib-src/ directories reported in the error message (lib-src/portmixer, lib-src/lib-widget-extra) and regenerated the configure files using `autoreconf --no-recursive -i`. Then I reran `./configure` and `make -B` and after that, the respective `.a` files were created. I'm not quite sure why this extra step is needed on my machine, but the linkage then proceeded without a hitch. ;)
Gale Andrews wrote: Have you tried the recommended
Code: Select all
mkdir build
Code: Select all
cd build
Code: Select all
No, I did not try that. Is this a general autotools wisdom, or did I miss some part of the audacity manual?
Post by steve » Mon Feb 29, 2016 3:54 pm
Witiko wrote:No, I did not try that. Is this a general autotools wisdom, or did I miss some part of the audacity manual?
I'm not sure if it is currently in the manual, but it was a tip given to me by one of the senior Audacity developers. Apparently it is fairly common practice to do this as it keeps the compiled object files separate from the source files, which is very helpful when developing on Linux.
Post by Gale Andrews » Mon Feb 29, 2016 5:53 pm
Certainly not in the Manual - any compilation help beyond that in the source code is "generally" on the Audacity Wiki (see link at the top).
Steve wrote a couple of walk-throughs for Ubuntu (at the top of http://forum.audacityteam.org/viewforum.php?f=19) but those assume the user does not compile wxWidgets.
Post by Gale Andrews » Mon Feb 29, 2016 6:03 pm
Glad it's working now. I am not sure why either, unless you have checked out more than once. Sometimes changes to latest Audacity HEAD may require you to regenerate the main configure file before running it.
