After upgrade to 2.1.2 problem with keyboard shortcuts
Please state:
jlwallen
Operating System: Linux Debian
Post by jlwallen » Fri Jan 22, 2016 4:12 pm
I've always used a set of custom keyboard shortcuts for working in Audacity.
Since upgrading to 2.1.2, one of those keyboard shortcuts refuses to work. I've always set Alt-Q to Start to Cursor/Selection Start. When I upgraded, that keyboard shortcut vanished and I every time I try to add it, it seems to add, but doesn't stick.
Has anyone come across such an issue and how would it be fixed?
Using Audacity on Elementary Freya OS.
Thank you.
Jack
Re: After upgrade to 2.1.2 problem with keyboard shortcuts
Post by Gale Andrews » Sat Jan 23, 2016 1:58 pm
Thanks for the report. Bug created at http://bugzilla.audacityteam.org/show_bug.cgi?id=1306.
