It was successful, but after modifying src/FFmpeg.h
692c692
< (const AVOutputFormat *f),
> (AVOutputFormat *f),
759c759
< (const AVFifoBuffer *f),
> (AVFifoBuffer *f),
805c805
< (const AVDictionary *m, const char *key, const AVDictionaryEntry *prev, int flags),
> (AVDictionary *m, const char *key, const AVDictionaryEntry *prev, int flags),
Otherwise it is not compatible with ffmpeg-2.8.5.
compilation of audacity 2.1.2
Please state:
Please state:
Re: compilation of audacity 2.1.2
Thanks toto56,
However, Audacity will work with some FFmpeg versions later than 2.3 if Audacity is compiled with the option:
if you have a unified diff against the current GitHub source, I'd be happy to pass it on to the developers, or you can yourself via the developers email list: http://audacityteam.org/contact/mailing-lists/
As it say in the manual http://manual.audacityteam.org/o/man/fa ... tml#ffdowntoto56 wrote:Otherwise it is not compatible with ffmpeg-2.8.5
Code: Select all
--disable-dynamic-loading
Reason: correct URL
Reason: correct URL
