GSnap VST plugin and Audacity v2.1.1
Please state:
DiversantB
Operating System: Linux Debian
Post by DiversantB » Wed Jan 20, 2016 2:30 am
I want to try this VST plugin but didn't succeed in installing it.
Is it possible to use Gsnap on v2.1.1? What exact version of Gsnap should I use 32bit or 64bit.
Where should I put .dll to use it? May be I sholuld change file permissions?
Here's some info on my system's Audacity build:
Code: Select all
Installed versions:  2.1.1^t[1](10:44:29 AM 01/12/2016)(alsa doc ffmpeg flac ladspa lame lv2 midi nls portmixer soundtouch vorbis vst -id3tag -jack -libav -mad -sbsms -twolame -vamp CPU_FLAGS_X86="sse")
Re: GSnap VST plugin and Audacity v2.1.1
Post by steve » Wed Jan 20, 2016 11:11 am
As far as I'm aware,GSnap does not work on Linux.
VST plug-ins are platform specific. Windows VSTs only work on Windows, Mac OS X VSTs only work on Macs, Linux VSTs (which are rare) only work on Linux.
Post by Gale Andrews » Wed Jan 20, 2016 11:14 pm
GSnap for Linux is beta, so use at your own risk: http://www.gvst.co.uk/portpage.htm.
Follow http://manual.audacityteam.org/o/man/ef ... u.html#vst to put the Gsnap.so (NOT .dll) file in a location Audacity searches, then open Effect > Manage... , select the effect, click Enable, then click OK.
DiversantB
Post by DiversantB » Thu Jan 21, 2016 9:21 am
Hope this works. I'll try. Thanks a lot.
