That is 'usually' the case (virtually "always" for consumer level sound cards), though some high level sound cards are able to handle multiple streams without help from Pulse.Gale Andrews wrote:If you want to use other audio apps while using Audacity you will have to use the workaround ...<snip>
download legacy version?
Please state:
Please state:
Re: download legacy version?
- Quality Assurance
Do you know any named examples, in case someone really wants that? I presume we're talking about hardware mixing?steve wrote:That is 'usually' the case (virtually "always" for consumer level sound cards), though some high level sound cards are able to handle multiple streams without help from Pulse.Gale Andrews wrote:If you want to use other audio apps while using Audacity you will have to use the workaround ...<snip>
The RME Hamerfall soundcards have hardware mixing, though I've never used one under Linux.
If I remember correctly, the old SoundBlaster AWE (10k1 / 10k2), but these are long obsolete - I'll dig my old one out when I get time and see if I can get it going
