A mate tried to compile it but he says, Audacity is unusuable because all "In-App-Icons" are empty. The Icons may be in one file and cannot be read. Hope you know what it could be.
Thanks a lot.
Verm
Audacity compiling on Solaris
Please state:
Please state:
Re: Audacity compiling on Solaris
Impossible to say without a lot more information, but I'd guess he may be missing a required graphics library. I'd suggest that he looks through the configure log for errors and warnings.
