As it says on http://wiki.audacityteam.org/wiki/Linux_Issues#pulse:drjoeross wrote:Is it possible to put this in a bach file like mos dos, that you can double click and run?
I tried creating a desktop file callerd ( "RunAudacity.desktop" ) but it did not work. I put this in the file -->
[Desktop Entry]
Name=Start-Audacity
Comment=test of online script
Exec=/home/DRJOEROSS/StartAudacity.sh <=== the wk around: env PULSE_LATENCY_MSEC=30 audacity
Icon=/home/DRJOEROSS/audacity.png
Terminal=true
Type=Application
So, if you are using GNOME flashback, you can right-click over the Audacity launcher and choose "Properties" then edit the command.to avoid opening the terminal each time, it may (depending on the distribution) be possible to add the required latency command directly to the application launcher. If not, you can (with root permissions) edit /usr/share/applications/audacity.desktop and insert the pulse latency command directly after "Exec=", for example:
Exec=env PULSE_LATENCY_MSEC=30 audacity %F
If you are using Unity, edit the existing audacity.desktop file. There is no need to call another script (and scripts don't run until you give them executable permissions).
