Hello All, I'm new to audacity and have a question I wasn't yet able to find an answer to by searching the forum (may have missed it).
I'm using audacity's spectrograms to view formant trajectories to help vowel pronunciation as I learn French. Using greyscale and playing with the settings I get beautiful formant trajectories and am ready to visually compare my "est-ce que vous-avez du fromage" with Paris's best speakers.
I find myself repeatedly doing the following manual sequence:
- record a phrase
- normalize to remove DC gain
- duplicate the track twice (ctrl-c, click to blank area, ctrl-v ctrl-v)
- in first duplicate, pull down "Spectrogram" (it has the "S" underlined so there must be a keystroke?)
- in the second duplicate, pull down log spectrogram
- use the mouse to vertically enlarge the two spectogram views
I had hoped to use "Edit chains -> Add" to automate but only managed to insert the Normalize step -- can the whole
sequence be automated to a keystroke using chains somehow? If not, what's the most natural way to automate these steps? I'm comfortable with C++ and Lisp, and could pick up Python if needed. I anticipate using audacity quite a bit going forward so don't mind investing some time.
my linux release is : ubuntu 14.04, Audacity version 2.0.5, but am happy to compile from fresh source etc.
Thanks!
Ashok Popat
Menlo Park, CA
chain or script spectrogram track creation and view
Please state:
Please state:
- Quality Assurance
Re: chain or script spectrogram track creation and view
Chains only adds effects and an optional export command. It isn't a macro recorder.
You could try for example https://code.google.com/p/autokey/ or https://github.com/polyethene/IronAHK or perhaps http://www.webupd8.org/2014/03/automate ... ionaz.html.
