Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
https://www.audacityteam.org/download/).
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Sun Aug 09, 2015 5:57 pm
mrbumpy409 wrote:Gale Andrews wrote:Ubuntu Handbook build Audacity with wx2.8.12. Did you compile Audacity yourself with 2.8.12? I am not aware of a problem with NUMPAD in effects on Linux with Audacity built using wx2.8.12 or wx3.
It was compiled using wx2.8.12.1. Should I try it with wx3 instead?
You could if you are able to - if wx3 fixes it, at least it would mean that we might not have to take any action. I cannot reproduce the issue with either "English US" layout on Ubuntu 14.04 with Audacity HEAD built with wx3.0.2.
I don't have Audacity 2.1.1 built with wx2.8.12 right now.
- Quality Assurance
Post
by Gale Andrews » Sun Aug 09, 2015 10:51 pm
Gale Andrews wrote:mrbumpy409 wrote:Gale Andrews wrote:Ubuntu Handbook build Audacity with wx2.8.12. Did you compile Audacity yourself with 2.8.12? I am not aware of a problem with NUMPAD in effects on Linux with Audacity built using wx2.8.12 or wx3.
I've rebuilt 2.1.1 with wx2.8.12 and I can confirm the issue there exactly as you describe (in UK and US English).
Audacity built with wx3.0.2 could be somewhat unstable for a week or two - we are still working out bugs due to the transition to the later wxWidgets version. I definitely would not build 2.1.1 release with wx3.0.2 as that has almost no wx3 fixes.
So you may want to wait for 2.1.2 release sometime at end of September/possibly early October which will require wx3.0.2.
mrbumpy409
Post
by mrbumpy409 » Mon Aug 10, 2015 12:07 am
Gale Andrews wrote:mrbumpy409 wrote:It was compiled using wx2.8.12.1. Should I try it with wx3 instead?
Unfortunately, Audacity 2.1.1 throws errors related to wxwidgets when trying to compile it with wx3.0.2, so I am unable to test if it resolves the numpad issue in version 2.1.1. I can, however, confirm that the current git pull
does fix the numpad issue.
