Audacity won't start on Ubuntu 13.04
Please state:
LeeMaiden
Re: Audacity won't start on Ubuntu 13.04
Post by LeeMaiden » Fri May 23, 2014 9:23 pm
It is a Microsoft LifeCam HD3000.
It works fine with Linux, which is why it was a surprise to me that it was the root of the problem.
Audacity opens in approximately 3.5 seconds now.
Post by Gale Andrews » Fri May 23, 2014 11:41 pm
LeeMaiden wrote:It is a Microsoft LifeCam HD3000.
Thanks, then it's the same camera family as the cam in defaria's report. But according to http://www.ideasonboard.org/uvc/, defaria's "Cinema" version of the web cam has a bandwidth hogging problem on Linux ( http://www.ideasonboard.org/uvc/#footnote-13 ).
