mixing stereo tracks
Please state:
davichap
Post by davichap » Fri Feb 28, 2014 10:35 am
hi
ive just downloaded audacity 2 for linux , but i cant see how to raise or lower the volume of each track seperately.ive recorded with a zoom h6 recorder just 2 instruments with the directional mics...i dont see the icon that has 2 triangles and a line through....
Re: mixing stereo tracks
Post by Gale Andrews » Fri Feb 28, 2014 2:35 pm
davichap wrote: ive just downloaded audacity 2 for linux
On Linux you usually install Audacity from your distribution's repository.
Which distribution?
What are all three numbers of the Audacity version? See the pink panel above.
davichap wrote:i cant see how to raise or lower the volume of each track seperately.ive recorded with a zoom h6 recorder just 2 instruments with the directional mics...i dont see the icon that has 2 triangles and a line through....
If you have hidden Tools Toolbar which has the Envelope Tool, see View > Toolbars.
You can also select each track (click above Mute / Solo to do that) and use Amplify or Normalize .
Or you can apply gain to each track using the -....+ sliders on each track. Gain is rendered to the waveform when you do Tracks > Mix and Render or when you export.
See Mixing Audio Tracks - Audacity Manual .
