USB cassette recording has intermittent drop-outs
Please state:
mynot
Post by mynot » Tue Feb 18, 2014 2:21 am
I'm trying to record from a usb cassette player (AWA) using Audacity 2.0.3 on Ubuntu 13.04. I've set it up according to Audacity's instructions (http://manual.audacityteam.org/o/man/re ... ables.html) - ALSA, USB Audio Controller codec.
Sound is being recorded but it has rapid, intermittent dropouts. (It sounds like what used to be called "motorboating" - don't know if the term is still current). On the waveform there's a pulse of sound for a fraction of a second, then silence for a fraction of a second, then sound and so on.
The waveform is only about 50% amplitude and anyway I've wound the player's volume right down. I've varied the "Project rate" from 8000 to 96000 with no difference.
Listening to the cassette the audio sounds file.
Any ideas please?
Thanks
Re: USB cassette recording has intermittent drop-outs
Post by kozikowski » Tue Feb 18, 2014 1:18 pm
Are you going through a USB hub with other equipment? That will cause serious problem like this. Are there USB things you can disconnect temporarily and see if the problem changes?
mynot
Post by mynot » Thu Feb 20, 2014 9:24 am
The only other usb device is a wireless mouse. I tried removing that while recording but it made no difference. Also, just to see what would happen, rebooted under Mint 15 and installed Audacity, but didn't improve things. Worked ok on my wife's Win 7 laptop. Thanks.
Post by Gale Andrews » Thu Feb 20, 2014 1:42 pm
If you are recording music you want 44100 Hz project rate to capture the full audible frequency range.
Try turning off Transport > Software Playthrough.
Try turning off as many other applications as you can. There are lots of other suggestions, such as increasing Audacity priority here: http://manual.audacityteam.org/o/man/fa ... html#skips .
Also you could install Wine - Run Windows applications on Linux then try the Windows version of Audacity from http://audacityteam.org/download/windows .
Post by steve » Thu Feb 20, 2014 4:46 pm
Try booting into Gnome fallback mode (if that is still an option in Ubuntu).
The "motorboating" is usually an indication that data is being dropped because some part of the system can't keep up. Reducing the load on the computer may help, particularly if the computer is not very powerful.
What options do you have selected in the device toolbar?
Post by Gale Andrews » Thu Feb 20, 2014 5:23 pm
steve wrote:Try booting into Gnome fallback mode (if that is still an option in Ubuntu).
That's still supported, but I don't think fallback is installed by default. If not,
Code: Select all
sudo apt-get install gnome-session-fallback
I find the main performance hit on Ubuntu is with the "Nautilus" file manager, and that's the case with either Unity or Gnome fallback. So if you have Nautilus open, try closing it down.
mynot
Post by mynot » Wed Feb 26, 2014 7:34 am
Thanks for the replies. I've done most of the straightforward things without any improvement. I've installed fallback, but how do I get to it? Wine doesn't seem to support usb devices - at least not without recompiling. In addition I've installed UbuntuStudio on a spare partition in the hope that the short latency might help, but it made no difference at all. So it looks like back to Windows, unfortunately.
Post by steve » Wed Feb 26, 2014 3:10 pm
steve wrote:What options do you have selected in the device toolbar?
Post by Gale Andrews » Wed Feb 26, 2014 3:22 pm
mynot wrote:I've installed fallback, but how do I get to it?
Log out of the computer then choose fallback at log in.
mynot
Post by mynot » Thu Feb 27, 2014 12:52 am
The devices toolbar has:
Audio Host = ALSA
Output Device = default
Input Device = USB Audio Controller: USB Audio (hw:1,0): Front Mic:0
(I've tried all other usb audio controller possibilities.)
Input Channels = 2 Stereo
