I'm using Crunchbang Linux 11
Audacity 2.0.1
One thing I need to do in Audacity is set the width of the value field in the Edit Metadata window. Every time I export a file, when the Edit Metadata window appears, the value field is always set to the default size which is to small for my needs. I am always resizing it. Is there a way to resize the value field and make it stick?
Setting default value size
Please state:
Please state:
- Attachments
- value.png (69.12 KiB) Viewed 2578 times
Re: Setting default value size
No there isn't.rmcellig wrote:Is there a way to resize the value field and make it stick?
However, it seems odd to me that the default size should be so small when there is empty space to the right of it.
I think this is a bug rather than by design.
When the Metadata Editor is closed, the screen position and size of the window are saved in preferences. Example:
Code: Select all
[TagsEditor]
x=61
y=192
width=530
height=405
There then seems to be a miscalculation of the column width for the "value" column, which always comes out as "174" when it should be sized according to the width of the window.
I've only tested on Linux (Debian/Gnome) so I don't know if the problem is specific to Linux.
It's really frustrating that I can't get the window size to be what I need it to be. Any other options I should try out? Maybe I'll try an older version in Puppy Linux just to see what happens.
Looking at the code I suspect the problem goes back to at least 2008.
If you are able to build Audacity from the source code I've made a patch that I think will fix it.
- Quality Assurance
The incorrect starting width of the "Value" column also occurs on Ubuntu, but not Windows or Mac OS X, so it's probably something that has not been coded correctly for wxGTK.rmcellig wrote:It's really frustrating that I can't get the window size to be what I need it to be. Any other options I should try out? Maybe I'll try an older version in Puppy Linux just to see what happens.
I created bugs for these while you were writing:
Bug 706 – Metadata Editor: Value column too small
Bug 707 – Metadata Editor: Width and height values in .cfg not respected .
so can you attach your patch as appropriate, Steve?
Done.Gale Andrews wrote:so can you attach your patch as appropriate, Steve?
