I generated the test waveform by speaking into a microphone plugged into front of my Toshiba laptop.
To center the waveform, using Audacity, I have to set:
Normalize maximum amplitude to: -50 db
From what I am reading about DCoffset in audacity documentation, I should instead adjust my hardware settings by downloading new drivers from the manufacturer. However, when I access the Toshiba website, I am only presented with a driver file in Windows executable format. However, I am using Linux, therefore I believe I am forced to use linux ALSA drivers.
The Toshiba Satellite laptop is running:
linux: Ubuntu 10.04.
Audacity 1.3.12-beta (downloaded via Synaptic)
I can hear the recorded voice on playback within Audacity.
only after I switched Playback and Recording settings:
FROM: the ALSA (default driver that I believe is appropriate for linux)
TO: HDA Intel: ALC268 Analog (hw 0,0)
Note that the same setting dialog box shows the setting: Interface: Host: ALSA
Audacity, Audio Device displays:
Code: Select all
Default capture device number: 7
Default playback device number: 7
Device ID: 0
Device name: ALSA: HDA Intel: ALC268 Analog (hw:0,0)
Input channels: 2
Output channels: 2
Low Input Latency: 0.011610
Low Output Latency: 0.011610
High Input Latency: 0.046440
High Output Latency: 0.046440
Supported Rates:
44100
48000
96000
192000
Device ID: 1
Device name: ALSA: front
Input channels: 0
Output channels: 2
Low Input Latency: -1.000000
High Input Latency: -1.000000
Supported Rates:
44100
48000
96000
192000
Device ID: 2
Device name: ALSA: surround40
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
96000
192000
Device ID: 3
Device name: ALSA: surround51
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
96000
192000
Device ID: 4
Device name: ALSA: surround71
Input channels: 0
Output channels: 2
Supported Rates:
44100
48000
96000
192000
Device ID: 5
Device name: ALSA: pulse
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 6
Device name: ALSA: dmix
Input channels: 0
Output channels: 2
Low Output Latency: 0.042667
High Output Latency: 0.042667
Supported Rates:
48000
Device ID: 7
Device name: ALSA: default
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 8
Device name: OSS: /dev/dsp
Input channels: 16
Output channels: 16
Supported Rates:
Selected capture device: 0 - ALSA: HDA Intel: ALC268 Analog (hw:0,0)
Selected playback device: 0 - ALSA: HDA Intel: ALC268 Analog (hw:0,0)
Supported Rates:
44100
48000
96000
Unable to open Portmixer
