Android ok?
Please state:
Please state:
Android ok?
Can I use audacity on my Samsung Android tablet?
- Quality Assurance
Re: Android ok?
Audacity does not run on Android - see http://manual.audacityteam.org/o/man/fa ... tml#mobile .
There are hacks to emulate other OS'es on Android ( https://play.google.com/store/apps/deta ... ator&hl=en ) or run an ARM port of Linux in a virtual machine ( see http://sourceforge.net/projects/linuxonandroid/ ) but there is no official version of Audacity for ARM architecture.
Re: Android ok?
Thanks man. I appreciate it.
Glenn
Glenn
