Slow track:Are the recorded tracks the same length irrespective of whether they play back correctly or too slow? Or is the slow track longer than it should be for the length that you recorded?
One minute (1:00) of stream = approx. 1:06 Audacity recording
When playback is correct:
1:00 = 1:00
Here are some interesting twists:
1. YouTube (Flash) streams now always seem to record correctly, although I have had problems with other Flash streams in the past.
2. When a Firefox tab is open containing a YouTube video I have played from, the tab which contains the problem (Vimeo) stream now records correctly.
3. When recording a Vimeo stream, Edit > Undo Record fails to remove the track as it ordinarily does after a single take.
4. After running Tracks > Remove Tracks after a slow Vimeo take, recording returns to normal speed, however, Edit > Undo Record still fails to remove the track.
The problem seems to be with Vimeo. Here is an example of the problem video: http://www.premrawat.com/category/updates/
A workaround is: 1. Record a slow take, 2. Tracks > Remove Tracks, 3. start recording and restart the stream. (However, Edit > Undo Record still fails to remove the track.)
