Audacity 2.0.5 compilation fails on Debian Squeeze
Please state:
Re: Audacity 2.0.5 compilation fails on Debian Squeeze
Post by steve » Fri Dec 20, 2013 6:44 pm
As described in the manual (http://manual.audacityteam.org/o/man/fa ... tml#ffdown),
The optional FFmpeg library allows Audacity to import and export a much larger range of audio formats including AC3, AMR(NB), M4A, MP4 and WMA and also audio from most video files.
FFmpeg is not required for Audacity to work, only to add support for non-open file formats.
There are also some legal considerations if you want to use FFmpeg: http://www.ffmpeg.org/legal.html
rulet
Post by rulet » Fri Dec 20, 2013 8:43 pm
When you planning to add support for newer versions of ffmpeg, at least that one which is in debian-multimedia repo for wheezy?
Post by Gale Andrews » Sat Dec 21, 2013 12:44 pm
rulet wrote:When you planning to add support for newer versions of ffmpeg, at least that one which is in debian-multimedia repo for wheezy?
When volunteers have time to upgrade, or we could take another route and export/import using the FFmpeg compiled binary instead of loading version-specific dynamic libraries (but making that once-only change is also a big job).
If you would like to volunteer to help with this, please subscribe to audacity-devel and introduce yourself: https://lists.sourceforge.net/lists/lis ... city-devel .
rulet
Post by rulet » Sat Dec 21, 2013 5:41 pm
Well, I probably could help but I'm not a programmer.
