xTux wrote:Hello,
Yes i have this BackTrack (5 r3 KDE).
I try but it does not work :/
Did you also try rebooting?
If you launch Audacity from the terminal are there any warnings or errors when recording stalls?
Have you tried pressing R on the keyboard instead of using the Record button? If you use pulse and you hold down Play or Record too long, Audacity can freeze.
xTux wrote:But i have a beta version ("Audacity ® 1.3.12-beta (Unicode)").
How to upgrade ?
What version do you have now? Look at Help > About Audacity.
The current release version is 2.0.3 so 1.3.12 is a downgrade from that. A 1.3.12 package that is meant for another version of BackTrack could be hard to install.
If you have less than 2.0.3, I would try uninstalling the Audacity versions you have now, then compile either the 2.0.3 tarball or 2.0.4 alpha (latest code). You can get these here:
http://audacityteam.org/download/source . Compilation instructions that should work on a Debian-based distribution are
here.
