Core dump when loading raw file
Please state:
doom_Oo7
Post by doom_Oo7 » Tue Jul 09, 2013 1:35 am
This happened to me right now, while trying to read a raw file, just after choosing it in the file manager (before the raw settings pop-up).
I use debian :
Code: Select all
Package: audacity
Version: 2.0.3-1
Installed-Size: 6761
Maintainer: Debian Multimedia Maintainers <[email protected]>
Architecture: amd64
Code: Select all
*** Error in `audacity': double free or corruption (out): 0x0000000002595320 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x7aa26)[0x7fa26f955a26]
/lib/x86_64-linux-gnu/libc.so.6(+0x7b7a3)[0x7fa26f9567a3]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0xf05f6)[0x7fa270d8f5f6]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(g_object_unref+0x1e8)[0x7fa2707b4578]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0xdda8b)[0x7fa270d7ca8b]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0xe1de4)[0x7fa270d80de4]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0x842ca)[0x7fa270d232ca]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0xb964f)[0x7fa270d5864f]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(g_closure_invoke+0xce)[0x7fa2707af55e]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(+0x220d5)[0x7fa2707c10d5]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(g_signal_emit_valist+0xe71)[0x7fa2707c8cd1]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(g_signal_emit+0x82)[0x7fa2707c8f82]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0x15ca60)[0x7fa270dfba60]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(g_object_run_dispose+0x60)[0x7fa2707b5680]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(g_closure_invoke+0x190)[0x7fa2707af620]
/usr/lib/x86_64-linux-gnu/libwx_gtk2u_core-2.8.so.0(_ZN8wxWindowD1Ev+0x10b)[0x7fa275d119eb]
/usr/lib/x86_64-linux-gnu/libwx_gtk2u_core-2.8.so.0(_ZN19wxGenericFileDialogD1Ev+0x194)[0x7fa275d19334]
audacity(_Z12FileSelectorPKwS0_S0_S0_S0_iP8wxWindow8wxStringPFvPviES4_+0x208)[0x724828]
audacity(_ZN15AudacityProject11OnImportRawEv+0x145)[0x5791c5]
audacity(_ZN14CommandManager18HandleCommandEntryEP16CommandListEntryjj+0x5f)[0x613caf]
audacity(_ZN15AudacityProject6OnMenuER14wxCommandEvent+0x2f)[0x59945f]
/usr/lib/x86_64-linux-gnu/libwx_baseu-2.8.so.0(_ZN12wxEvtHandler21ProcessEventIfMatchesERK21wxEventTableEntryBasePS_R7wxEvent+0x56)[0x7fa27566e9c6]
/usr/lib/x86_64-linux-gnu/libwx_baseu-2.8.so.0(_ZN16wxEventHashTable11HandleEventER7wxEventP12wxEvtHandler+0xa4)[0x7fa27566eb34]
/usr/lib/x86_64-linux-gnu/libwx_baseu-2.8.so.0(_ZN12wxEvtHandler12ProcessEventER7wxEvent+0xc7)[0x7fa27566ee57]
/usr/lib/x86_64-linux-gnu/libwx_gtk2u_core-2.8.so.0(+0x241036)[0x7fa275d50036]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(+0x21e30)[0x7fa2707c0e30]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(gtk_widget_activate+0x7c)[0x7fa270eec0cc]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(gtk_menu_shell_activate_item+0xfd)[0x7fa270de7c9d]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0x14903c)[0x7fa270de803c]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0x135f19)[0x7fa270dd4f19]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(+0x21b1b)[0x7fa2707c0b1b]
/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0(g_signal_emit_valist+0xb12)[0x7fa2707c8972]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(+0x24de9e)[0x7fa270eece9e]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(gtk_propagate_event+0xc4)[0x7fa270dd3284]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(gtk_main_do_event+0x28b)[0x7fa270dd35eb]
/usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0(+0x5b80c)[0x7fa270a4980c]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x135)[0x7fa2704ebf25]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x49268)[0x7fa2704ec268]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_loop_run+0x6a)[0x7fa2704ec6da]
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0(gtk_main+0xa7)[0x7fa270dd25e7]
/usr/lib/x86_64-linux-gnu/libwx_gtk2u_core-2.8.so.0(_ZN11wxEventLoop3RunEv+0x48)[0x7fa275cfdf98]
/usr/lib/x86_64-linux-gnu/libwx_gtk2u_core-2.8.so.0(_ZN9wxAppBase8MainLoopEv+0x4c)[0x7fa275d6699c]
/usr/lib/x86_64-linux-gnu/libwx_baseu-2.8.so.0(_Z7wxEntryRiPPw+0x75)[0x7fa275620625]
======= Memory map: ========
00400000-00a04000 r-xp 00000000 08:11 276725                             /usr/bin/audacity
00c04000-00c05000 r--p 00604000 08:11 276725                             /usr/bin/audacity
00c05000-00c79000 rw-p 00605000 08:11 276725                             /usr/bin/audacity
00c79000-00ca1000 rw-p 00000000 00:00 0
01c84000-02635000 rw-p 00000000 00:00 0                                  [heap]
7fa238000000-7fa238022000 rw-p 00000000 00:00 0
7fa238022000-7fa23c000000 ---p 00000000 00:00 0
7fa23c000000-7fa23c022000 rw-p 00000000 00:00 0
7fa23c022000-7fa240000000 ---p 00000000 00:00 0
7fa240000000-7fa240022000 rw-p 00000000 00:00 0
7fa240022000-7fa244000000 ---p 00000000 00:00 0
7fa244000000-7fa244022000 rw-p 00000000 00:00 0
7fa244022000-7fa248000000 ---p 00000000 00:00 0
7fa248000000-7fa248022000 rw-p 00000000 00:00 0
7fa248022000-7fa24c000000 ---p 00000000 00:00 0
7fa24c000000-7fa24c021000 rw-p 00000000 00:00 0
7fa24c021000-7fa250000000 ---p 00000000 00:00 0
7fa250000000-7fa250022000 rw-p 00000000 00:00 0
7fa250022000-7fa254000000 ---p 00000000 00:00 0
7fa254256000-7fa258000000 r--p 00000000 08:11 524141                     /usr/share/icons/gnome/icon-theme.cache
7fa258000000-7fa258021000 rw-p 00000000 00:00 0
7fa258021000-7fa25c000000 ---p 00000000 00:00 0
7fa25d3b2000-7fa25d3b3000 ---p 00000000 00:00 0
7fa25d3b3000-7fa25dbb3000 rw-p 00000000 00:00 0
7fa25dbb3000-7fa25dbb4000 ---p 00000000 00:00 0
7fa25dbb4000-7fa25e3b4000 rw-p 00000000 00:00 0
7fa25ebb5000-7fa25ebb6000 ---p 00000000 00:00 0
7fa25ebb6000-7fa25f3b6000 rw-p 00000000 00:00 0                          [stack:13298]
7fa25f56e000-7fa25f56f000 ---p 00000000 00:00 0
7fa25f56f000-7fa25fd6f000 rw-p 00000000 00:00 0                          [stack:13303]
7fa25fd6f000-7fa25fd70000 ---p 00000000 00:00 0
7fa25fd70000-7fa260570000 rw-p 00000000 00:00 0
7fa260570000-7fa260571000 ---p 00000000 00:00 0
7fa260571000-7fa260d71000 rw-p 00000000 00:00 0                          [stack:13330]
7fa260d71000-7fa260d81000 r-xp 00000000 08:11 403658                     /usr/lib/x86_64-linux-gnu/gio/modules/libgioremote-volume-monitor.so
7fa260d81000-7fa260f81000 ---p 00010000 08:11 403658                     /usr/lib/x86_64-linux-gnu/gio/modules/libgioremote-volume-monitor.so
7fa260f81000-7fa260f82000 r--p 00010000 08:11 403658                     /usr/lib/x86_64-linux-gnu/gio/modules/libgioremote-volume-monitor.so
7fa260f82000-7fa260f83000 rw-p 00011000 08:11 403658                     /usr/lib/x86_64-linux-gnu/gio/modules/libgioremote-volume-monitor.so
7fa260f83000-7fa2610dd000 r-xp 00000000 08:11 289561                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.1
7fa2610dd000-7fa2612dc000 ---p 0015a000 08:11 289561                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.1
7fa2612dc000-7fa2612e4000 r--p 00159000 08:11 289561                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.1
7fa2612e4000-7fa2612e6000 rw-p 00161000 08:11 289561                     /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.1
7fa2612e6000-7fa2612e7000 rw-p 00000000 00:00 0
7fa2612e7000-7fa26131e000 r-xp 00000000 08:11 267568                     /usr/lib/x86_64-linux-gnu/libcroco-0.6.so.3.0.1
7fa26131e000-7fa26151d000 ---p 00037000 08:11 267568                     /usr/lib/x86_64-linux-gnu/libcroco-0.6.so.3.0.1
7fa26151d000-7fa261520000 r--p 00036000 08:11 267568                     /usr/lib/x86_64-linux-gnu/libcroco-0.6.so.3.0.1
7fa261520000-7fa261521000 rw-p 00039000 08:11 267568                     /usr/lib/x86_64-linux-gnu/libcroco-0.6.so.3.0.1
7fa261521000-7fa261555000 r-xp 00000000 08:11 268013                     /usr/lib/x86_64-linux-gnu/librsvg-2.so.2.36.4
7fa261555000-7fa261754000 ---p 00034000 08:11 268013                     /usr/lib/x86_64-linux-gnu/librsvg-2.so.2.36.4
7fa261754000-7fa261755000 r--p 00033000 08:11 268013                     /usr/lib/x86_64-linux-gnu/librsvg-2.so.2.36.4
7fa261755000-7fa261756000 rw-p 00034000 08:11 268013                     /usr/lib/x86_64-linux-gnu/librsvg-2.so.2.36.4
7fa261756000-7fa261758000 r-xp 00000000 08:11 268009                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
7fa261758000-7fa261957000 ---p 00002000 08:11 268009                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
7fa261957000-7fa261958000 r--p 00001000 08:11 268009                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
7fa261958000-7fa261959000 rw-p 00002000 08:11 268009                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
7fa261959000-7fa261987000 r-xp 00000000 08:11 283471                     /usr/lib/x86_64-linux-gnu/libbluray.so.1.1.0
7fa261987000-7fa261b87000 ---p 0002e000 08:11 283471                     /usr/lib/x86_64-linux-gnu/libbluray.so.1.1.0
7fa261b87000-7fa261b88000 r--p 0002e000 08:11 283471                     /usr/lib/x86_64-linux-gnu/libbluray.so.1.1.0
7fa261b88000-7fa261b89000 rw-p 0002f000 08:11 283471                     /usr/lib/x86_64-linux-gnu/libbluray.so.1.1.0
7fa261b89000-7fa261b8b000 r-xp 00000000 08:11 1204916                    /lib/x86_64-linux-gnu/libutil-2.17.so
7fa261b8b000-7fa261d8a000 ---p 00002000 08:11 1204916                    /lib/x86_64-linux-gnu/libutil-2.17.so
7fa261d8a000-7fa261d8b000 r--p 00001000 08:11 1204916                    /lib/x86_64-linux-gnu/libutil-2.17.so
7fa261d8b000-7fa261d8c000 rw-p 00002000 08:11 1204916                    /lib/x86_64-linux-gnu/libutil-2.17.so
7fa261d8c000-7fa261d99000 r-xp 00000000 08:11 1175381                    /lib/x86_64-linux-gnu/libudev.so.0.13.0
7fa261d99000-7fa261f99000 ---p 0000d000 08:11 1175381                    /lib/x86_64-linux-gnu/libudev.so.0.13.0
7fa261f99000-7fa261f9a000 r--p 0000d000 08:11 1175381                    /lib/x86_64-linux-gnu/libudev.so.0.13.0
7fa261f9a000-7fa261f9b000 rw-p 0000e000 08:11 1175381                    /lib/x86_64-linux-gnu/libudev.so.0.13.0
7fa261f9b000-7fa261fb3000 r-xp 00000000 08:11 284574                     /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
7fa261fb3000-7fa2621b2000 ---p 00018000 08:11 284574                     /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
7fa2621b2000-7fa2621b3000 r--p 00017000 08:11 284574                     /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
7fa2621b3000-7fa2621b4000 rw-p 00018000 08:11 284574                     /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
7fa2621b4000-7fa2621dd000 r-xp 00000000 08:11 402126                     /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
7fa2621dd000-7fa2623dd000 ---p 00029000 08:11 402126                     /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
7fa2623dd000-7fa2623de000 r--p 00029000 08:11 402126                     /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
7fa2623de000-7fa2623df000 rw-p 0002a000 08:11 402126                     /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
7fa2623df000-7fa26259a000 r--p 00000000 08:11 529324                     /usr/share/icons/hicolor/icon-theme.cache
7fa26259a000-7fa26259b000 ---p 00000000 00:00 0
7fa26259b000-7fa262d9b000 rw-p 00000000 00:00 0
7fa262d9b000-7fa262dad000 r-xp 00000000 08:11 286586                     /usr/lib/x86_64-linux-gnu/libspeexdsp.so.1.5.0
7fa262dad000-7fa262fac000 ---p 00012000 08:11 286586                     /usr/lib/x86_64-linux-gnu/libspeexdsp.so.1.5.0
7fa262fac000-7fa262fad000 rw-p 00011000 08:11 286586                     /usr/lib/x86_64-linux-gnu/libspeexdsp.so.1.5.0
7fa262fad000-7fa262faf000 r-xp 00000000 08:11 537878                     /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_rate_speexrate.so
7fa262faf000-7fa2631ae000 ---p 00002000 08:11 537878                     /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_rate_speexrate.so
7fa2631ae000-7fa2631af000 r--p 00001000 08:11 537878                     /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_rate_speexrate.so
7fa2631af000-7fa2631b0000 rw-p 00002000 08:11 537878                     /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_rate_speexrate.so
7fa2631b0000-7fa2631b6000 r-xp 00000000 08:11 265375                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-xpm.so
7fa2631b6000-7fa2633b5000 ---p 00006000 08:11 265375                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-xpm.so
7fa2633b5000-7fa2633b6000 r--p 00005000 08:11 265375                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-xpm.so
7fa2633b6000-7fa2633b7000 rw-p 00006000 08:11 265375                     /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-xpm.so
7fa2633b7000-7fa2633bd000 r-xp 00000000 08:11 533287                     /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_pcm_pulse.so
7fa2633bd000-7fa2635bc000 ---p 00006000 08:11 533287                     /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_pcm_pulse.so
7fa2635bc000-7fa2635bd000 r--p 00005000 08:11 533287                     /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_pcm_pulse.soAbandon
Re: Core dump when loading raw file
Post by kozikowski » Tue Jul 09, 2013 3:19 am
Where did you get this file from and how big is it? Is it likely to expand to over 13 hours of show? Koz
doom_Oo7
Post by doom_Oo7 » Tue Jul 09, 2013 3:39 am
No, it is a very small raw file (300 kilobytes).
I tried reopening it and it worked, but this has already happened to me while opening other raw files.
