I removed voice from mp3. Good tool for this job is Vocal remover. Music is perfect. But some scrape is still in track. Have somebody any idea for cleaning this? Thanks for tips.
I have Audacity 2.0.0, Ubuntu 12.04
Remove scrape from track
Please state:
Please state:
- Attachments
- audio.mp3
- sample track
- (264.49 KiB) Downloaded 197 times
Re: Remove scrape from track
I don't think that you can. I think that is about as good as it gets. You could try mixing in some other sounds (perhaps a hi-hat) to cover it up a bit.vanad wrote:Have somebody any idea for cleaning this?
