Playback of imported/recorded files distorted and fast.
Please state:
shinobi9
Re: Playback of imported/recorded files distorted and fast.
Post by shinobi9 » Tue Nov 25, 2014 11:16 am
I had the same thing happen with Ubuntu 14.04, After running pavucontrol, I realized I had setup for 5.1 sourround, I switched back to 2 Channel Stereo, and the issue vanished.
This may not be your issue, but hopefully it may help somebody sometime.
Thanks for the great posts, this page helped me work out a solution.
rcrath
Post by rcrath » Tue Jan 13, 2015 1:14 am
I had this problem in my manjaro distro too. seems specific to the distro. Ill submit something downstream there. different things tried and now it works. First was to change the driver in settings...I thought I changed from default or pulseaudio to alsa, but now I don't see an alsa setting...anyway try fiddling there. Then I installed all the pulseaudio applets and widgets and ran the env variable suggested above. Now it plays back properly, including after rebooting.
