is it possible to record sound from sound card while listening to sounds ?
like audio hijack pro on mac os x ?
Please state:
Please state:
harlockyoumetech
Re: is it possible to record sound from sound card while lis
Yesharlockyoumetech wrote:is it possible to record sound from sound card while listening to sounds ?
No idea - I don't use Macs.harlockyoumetech wrote:like audio hijack pro on mac os x ?
I guess the next question is "how"? You will need to say a bit about your current set-up (hardware and software).
- Quality Assurance
You posted in the Linux board. If you want to know about recording computer playback on Linux, please see here:steve wrote:Yesharlockyoumetech wrote:is it possible to record sound from sound card while listening to sounds ?
http://manual.audacityteam.org/o/man/tu ... linux.html .
Mac's don't provide a recording device for the sound card that can capture sounds playing on the computer.
However you can use Audio Hijack Pro if you wish to spend money. This grabs sound from the application playing the audio before it gets to the sound card. For technical support with Audio Hijack Pro, see http://rogueamoeba.com/support/ .
If you don't want to spend money you can record computer playback into Audacity using a loopback cable or by downloading Soundflower. Please see here http://manual.audacityteam.org/o/man/tu ... n_mac.html .
