Every 5 seconds I get a pop or noise spike.
Please state:
Please state:
I am runing Ubuntu on an older Acer Aspire one netbook. When I use Audacity to record audio from a digital recorder or FM radio I get very loud pops exactly every 5 seconds. It pretty much makes the audio unuseable. I suspect that the netbook may not have enough processing power and may be glitching when too much is going on. Any ideas? Thanks duder
Re: Every 5 seconds I get a pop or noise spike.
You mean a "real" radio - not software - connected to your computer somehow?duder wrote:When I use Audacity to record audio from a digital recorder or FM radio
How is the radio connected to the computer?
That's possible,duder wrote:I suspect that the netbook may not have enough processing power and may be glitching when too much is going on.
Yes its a real battery powered AM FM radio. I use a stereo cable with the small 3.5mm jacks to go into my mic input on my netbook. I usually record mono on Audacity. Also I use the same cable to mic jack setup for the digital recorder.
I had also though maybe I was over driving the input, but it seems like the actual recorded sound is OK.
Is Ubuntu up to date?
Which version of Audacity? (look in "Help > About Audacity")
Go into "Edit menu > Preferences > Recording" and set "Audio to buffer" to 200. Does that make any difference (better or worse)?
What are the available options in Device Toolbar?
The OS should be up to date, I just installed up dates this morning. The version of audacity version is 2.0.0
I found when i turn up the quality to 24 bit 32000 sample rate the noise goes away. However it slows way down. I made some 10 second test clips and once I click stop its take about 30 seconds for it to catchup.
Dr. Killjoy
I also get the same problem, I guess.
I'm running Audacity 2.0.3 on Linux Mint 15 64bit Cinnamon on a desktop computer. I can play long interviews without any trouble, but sometimes, when I start doing the montage when removing audio, I hear clicks/pops. And then, on playback, every 5 seconds or so.
Does this have to do with the block files that don't connect to each other very well?
And how come I don't get this error all the time?
I am already recording and playing on 32000 bits.
What is the specification / model number of your Acer Aspire?
Ubuntu is about the "heaviest" of all Linux distributions, so may not be well suited to an older machine. I use Debian Squeeze on an Aspire 5735 with Gnome Classic desktop. On an even older machine (Pentium II 500 MHz) I use Debian with XFCE desktop.
Dr. Killjoy
If you're asking me, I'm not using a notebook or netbook. Working on a desktop computer.
AMD Dual core processor 4200+ 2,4 GB RAM
I was asking the OP (duder).Dr. Killjoy wrote:If you're asking me
- Quality Assurance
Ubuntu was still quite workable on lower powered machines until 10.x. I seriously question that current versions are usable at their stated minimum requirements of 1 GHz, 512 MB RAM (if you want to keep GNOME).steve wrote:Ubuntu is about the "heaviest" of all Linux distributions, so may not be well suited to an older machine.
