Deleting silence labels
Please state:
vhradice
Post by vhradice » Mon Apr 22, 2013 11:46 pm
I am new to Audacity and I am having a problem separating a file into tracks. I have captured one side of a vinyl album into 1 file - about 20 minutes. There are 7 songs in the file. When I use the Analyze - Silence finder to separate the tracks, I get 10 markers. I would like to get rid of some of them as there are short durations of silence after a piano intro into the song at the start of some of the songs. I can't find any way in the documentation that tells how to delete one of these labels. I have discovered that if I save it with Export Multiple the piano will be saved as a separate file - not what I want.
Thanks in advance,
Vince Radice
Re: Deleting silence labels
Post by Gale Andrews » Tue Apr 23, 2013 12:53 am
vhradice wrote:I am new to Audacity and I am having a problem separating a file into tracks. I have captured one side of a vinyl album into 1 file - about 20 minutes. There are 7 songs in the file. When I use the Analyze - Silence finder to separate the tracks, I get 10 markers. I would like to get rid of some of them as there are short durations of silence after a piano intro into the song at the start of some of the songs.
Edit > Undo Silence Finder and try increasing the silence level and duration (the first two controls).
vhradice wrote:I can't find any way in the documentation that tells how to delete one of these labels.
Please see http://manual.audacityteam.org/o/man/la ... tml#remove .
vhradice
Post by vhradice » Tue May 07, 2013 8:01 pm
I have tried that and is has worked to an extent. There were some times when the interlude was several seconds long - longer that the time between tracks. I was able to split the recording into tracks by inserting more silence between tracks. Can the offending markers be moved out of the way - like the end of the recording? It would be very helpful if the offending markers could easily be deleted.
Post by Gale Andrews » Thu May 09, 2013 6:59 am
vhradice wrote: Can the offending markers be moved out of the way - like the end of the recording? It would be very helpful if the offending markers could easily be deleted.
Please read the link already provided http://manual.audacityteam.org/o/man/la ... tml#remove . Try clicking in the label, press HOME on your keyboard, hold SHIFT then press END, then press DELETE twice.
waxcylinder
Post by waxcylinder » Thu May 09, 2013 10:05 am
perhaps the easiest way to delete unwanted labels is the select the range in the label track that contains the unwanted label(s) and then use the keyboard shortcut CTRL+ALT+K (a little tip/trick that I learnt from Gale recently) :)
The shortcut is for the menu command Edit > Remove Audio or Labels > Split Delete - see this page in the manual: http://manual.audacityteam.org/o/man/ed ... lit_delete
but the shortcut is much easier methinks 8-)
UPDATE: I just noticed this is the MAC forum so the shortcut is probably CMD+ALT+K
