compilation error
Please state:
dom55
compilation error
Post by dom55 » Mon Apr 15, 2013 6:40 am
Hello
The compilation of the sources (obtained from the svn repository of audacity) gives some fatal errors given below:
does somebody understand what is the matter ?
the ./configure didn't show fatal error.
he OS is OpenSuse 12.2 64 bits.
thank you for your help
Dom
make[1] : on entre dans le répertoire « /home/dom/audacity/src »
g++ -c -I../lib-src/portmixer/include -Wall -I/usr/lib64/wx-2.8-stl/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ -pthread -I../lib-src/FileDialog -I/home/dom/audacity/lib-src/lib-widget-extra -I../lib-src/libsndfile/src -I../lib-src/libid3tag -I../lib-src/libsoxr/src -I../lib-src/sbsms/include -I../lib-src/soundtouch/include -I../lib-src/libnyquist -I../lib-src/libvamp -I../lib-src/expat -I../lib-src/twolame/libtwolame -I../lib-src/portsmf -I../lib-src/portaudio-v19/include -fno-strict-aliasing -I./include -I. -DLIBDIR="/usr/local//lib64" -D__STDC_CONSTANT_MACROS -Wall -pthread -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng14 AudacityApp.cpp -o AudacityApp.o
In file included from WaveTrack.h:17:0,
from AudioIO.h:35,
from AudacityApp.cpp:61:
WaveClip.h:57:1: warning: type attributes ignored after type is already defined [-Wattributes]
In file included from AudacityApp.cpp:70:0:
FFmpeg.h:356:4: error: ‘SampleFormat’ does not name a type
FFmpeg.h:585:4: error: use of enum ‘SampleFormat’ without previous declaration
FFmpeg.h:622:4: error: ‘AVFormatParameters’ has not been declared
FFmpeg.h:639:4: warning: ‘av_register_protocol_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:639:4: error: ‘URLProtocol’ was not declared in this scope
FFmpeg.h:639:4: error: ‘protocol’ was not declared in this scope
FFmpeg.h:639:4: error: ‘av_register_protocol’ declared as an ‘inline’ variable
FFmpeg.h:639:4: error: expected ‘,’ or ‘;’ before ‘{’ token
FFmpeg.h: In function ‘AVCodec* av_codec_next(AVCodec*)’:
FFmpeg.h:686:4: error: declaration of C function ‘AVCodec* av_codec_next(AVCodec*)’ conflicts with
In file included from FFmpeg.h:39:0,
Re: compilation error
Post by steve » Mon Apr 15, 2013 8:04 am
Check which version of FFMpeg you have installed.
Currently supported versions are 0.5 through 0.8. http://manual.audacityteam.org/o/man/fa ... html#linff
If you don't have a supported version of FFMpeg, the easiest workaround is to build Audacity without FFMpeg support.
The following commands should reset the configuration and build without FFMpeg support:
Code: Select all
make distclean
./configure --without-ffmpeg
make
The down side of building without FFMpeg is that you lose support for proprietary file formats that are supported by FFMpeg, such as WMA, AAC, and so on.
auduser2
Post by auduser2 » Sun Jan 12, 2014 11:40 pm
Use the ffmpeg-comat includes in src/FFmpeg.h
#include <ffmpeg-compat/libavcodec/avcodec.h>
#include <ffmpeg-compat/libavformat/avformat.h>
#include <ffmpeg-compat/libavutil/fifo.h>
#include <ffmpeg-compat/libavutil/mathematics.h>
I just added them before the others and it compiled for me.
Post by steve » Mon Jan 13, 2014 12:43 pm
auduser2 wrote:Use the ffmpeg-comat includes in src/FFmpeg.h
Which Linux distro?
Did you need to install ffmpeg-compat-devel separately or was it already installed on your machine?
I've not found much documentation about ffmpeg-compat. Is that the "correct" way to use FFmpeg-compat or is it a "hack"?
