Replaygain not working on mp3 files
Please state:
Please state:
Audacious 3.2.3 on Mint 14 (installed from Ubuntu repository) does not seem to use the replaygain values stored in mp3 files. Replaygain does appear to work with FLAC encoded files. I think I'm going to complile from source and see if the problem persists.
- Quality Assurance
Re: Replaygain not working on mp3 files
Please note that Audacious is nothing to do with the Audacity project. You will need to raise your issue with Audacious http://audacious-media-player.org/ .dhurler wrote:Audacious 3.2.3 on Mint 14 (installed from Ubuntu repository) does not seem to use the replaygain values stored in mp3 files. Replaygain does appear to work with FLAC encoded files. I think I'm going to complile from source and see if the problem persists.
