1.) I installed Chrubuntu 13.04, a xubuntu variant, using this tutorial. http://www.whatthetech.info/installing- ... hromebook/
2.) I got at least the sound playback fixed using: http://www.whatthetech.info/fixing-soun ... chrubuntu/
My next step is getting Audacity to run, but so far no luck! I've installed Audacity using both Ubuntu's software manager and the Synaptic kit, just in case there was some slight deviation, but after installing Audacity and opening it in Applications/Multimedia/Audacity, nothing happens! (I am currently using the Synaptic repository). If you try to run it a second time, it presents the following error message:
"The system has detected that another copy of Audacity running.
Running two copies of Audacity simultaneously may cause data loss or cause your system to crash.
Use the New or Open commands in the currently running Audacity process to open multiple projects simultaneously." (OK)
After rebooting, I fired up the terminal emulator and tried audacity and got:
Code: Select all
[email protected]:-$ audacity
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2217(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
bt_audio_service_open: connect() failed: Connection refused (111)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1670
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1830
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2092
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2764
