Input/Output dropdown lists bug
Please state:
Please state:
Stratovarius
The Audacity input/ouput dropdowns are too short for some of the idiotic "yard-and-a-half" names popping up all over the place lately. The result is that for TerraTec only the front part shows which is always the same. There IS a bubble on mouseover but it's too small and shows the nature of the selection rather then the full selected name. Maybe we'd need a double bubble to be more indicative or everything or maybe truncated descriptors(?).
waxcylinder
Re: Input/Output dropdown lists bug
You can widen the Device Toolbar by clicking on the bar at the right and dragging it rightwards.
For what it's worth, the "yard and a half" length names are not made up by Audacity, they are abbreviations
of the ALSA device name.
Stratovarius
I didn't say they were Audacity's doing, but they are a worsening plague.
Stratovarius
thanks, i'll try that as a countermeasure
waxcylinder
BTW the other toolbar that's really worth widening is the Meter Toolbar (it's about as useful as a chocolate fire-guard at its default size imho)
I have mine spread across the whole width of the Audacity Window.
