Hi, new to Audacity so I apologise for any misunderstandings I may have.
I want to import 20 or so mp3 files (which I've done), and then select around 20-30 seconds of each, and build one output track that has these 20 short selections played in sequence with a 2-3 second gap between them (this is for a quiz I'm running).
I've imported the tracks, and I've created selection labels 20-30 extract I want for the first three tracks, but I'm struggling with how to place those little tracklets into a new track to play sequentially.
I'm not necessarily looking for step by step instructions (although that would be nice!), but just a guide as to the process to follow. I'm not even sure that using selection labels is the best way of doing this.
Thanks for any help -
Backseat
Help creating montage ("quiz tape")
Please state:
Please state:
Robert J. H.
Re: Help creating montage ("quiz tape")
You can try my plug-in:
http://forum.audacityteam.org/viewtopic ... 9e#p190928
The only thing you have to do is to put your different parts isolated one under the other in new tracks.
You can move the pre-labeled parts with ctrl-i and ctrl-d into new tracks isolate/duplicate).
The gap between the parts can freely be chosen. Ask if you have any questions.
If you are going to play these on an MP3 player, could you make a "play list" for the MP3 player?
Yes, I'm starting to think that just making the 20-30 second snippets I want and keeping them as separate tracks is easier all round.
Thanks for the suggestions.
