I am using Ubuntu Studio 12.04 LTS and audacity from the standard repository.
I am struggling to get my new E-MU 1212 Audigity 2 sound card to play some sound.
In this process I apparently have made some mistake, since the Audacity recording device list it 2 km long, and contains every sub-sub device shown in alsamixer for the E-MU card. Things like dsp 0, dsp1, adat ... and not the normal device list. And of course, nothing works.
The strange thing is that everything looks normal for "aplay -l" and "aplay -L", so this is specific for Audacity.
What could have happened?
(And do I need to add that I have not yet gotten any sound out of my E-MU 1212?)
Wrong input device list - sound broken?
Please state:
Please state:
Re: Wrong input device list - sound broken?
You need to fix that first. Don't bother trying to get Audacity working until your sound card is working properly as you are unlikely to have any success, just waste a lot of time, effort and frustration.bnilsson wrote:(And do I need to add that I have not yet gotten any sound out of my E-MU 1212?)
Do you have alsa-firmware installed?
Try checking the Ubuntu forum for suggestions of how to get the E-MU 1212 running properly (From what I've seen on Google this card is "sort of" supported by ALSA but is not straightforward).
