PC crashed, audacity won't start now[SOLVED]
Please state:
Please state:
My PC locked up with Audacity open. After restarting the PC several times, when I start Audacity, I get the following "The system has detected that another copy of Audacity is running." and won't start. I'm running Ubuntu 12.04 and Audacity 2.0.0. I've tried killall audacity, deleting the audacity data dir and reinstalling audacity. Please help. All my data was saved. I just need to use Audacity for my daughter's music.
Re: PC crashed, audacity won't start now
When it crashed Audacity may have left its "lock file" behind.
The default location for temporary Audacity files is /var/tmp/audacity-<username>/
(where <username> is your user name).
If that directory is present, look in there for a file called audacity-lock-<username>
If it's there:
First, run "killall audacity" (just to check)
then delete audacity-lock-<username>.
If it's there:
Re: PC crashed, audacity won't start now[SOLVED]
Thank you! It worked beautifully.
