Hi All
I just upgraded my system to Ubuntu 12.10 and use the Gnome Legacy interface. All the menues that are usually along the top menu are missing. file, edit, view, tracks ... all missing. I checked on laptop and netbook I have and all look the same. From the ubuntu software install tool I think this is version 2.0.1-1 but can't get to the help menu to check about.
I tried to remove/reinstall and it looks the same.
I attached a screen shot of the window.
Suggestions???
Thanks
Steve S.
menu problem under ubuntu 12.10[SOLVED]
Please state:
Please state:
- Quality Assurance
Re: menu problem under ubuntu 12.10
Nothing was attached.sjs_bebop wrote:I just upgraded my system to Ubuntu 12.10 and use the Gnome Legacy interface. All the menues that are usually along the top menu are missing. file, edit, view, tracks ... all missing. I checked on laptop and netbook I have and all look the same. From the ubuntu software install tool I think this is version 2.0.1-1 but can't get to the help menu to check about.
It's an Ubuntu bug affecting applications built with wxwidgets, see https://bugs.launchpad.net/ubuntu/+sour ... bug/662077 .
One way of fixing it is to open a terminal and type:
Code: Select all
sudo apt-get purge appmenu-gtk appmenu-gtk3 appmenu-qt
Re: menu problem under ubuntu 12.10[SOLVED]
Code: Select all
sudo apt-get purge appmenu-gtk appmenu-gtk3 appmenu-qtSteve S.
