Hi
Im using JACK with Audacity, should the Latency Correction be set to the same value as JACKs latency?
cheers
Hi
cheers
I suggest setting “Latency correction” in Audacity to whatever value leaves your tracks synchronised after doing a Latency Test .
Grand, this is really helpful info, thanks
