Can't export mp3 to network location in Ubuntu
Please state:
chrislebaron
Post by chrislebaron » Wed Aug 01, 2012 10:17 pm
I'm currently using Audacity on Ubuntu 12.04, and I want to export my final product to a network location. (I'm working on a large tape to mp3 conversion, and need to save everything in a central location) Currently I can't see any network locations from the export menu. Is there a fix for that?
Thanks,
Chris
Re: Can't export mp3 to network location in Ubuntu
Post by steve » Thu Aug 02, 2012 1:51 am
You need to mount the network location as a drive.
Alternatively, export files temporarily to the local drive then upload to the network in whatever way you normally use to write to that location.
