OS
Fedora 35, Cinnamon spin
Audacity about screen - installed by dnf command
The Build
Program build date:
Apr 10 2022
Commit Id:
ff6d67 of Wed Dec 22 16:35:36 2021 +0100
Build type:
CMake Debug build (debug level 1), 64 bits
Compiler:
GCC 11.2.1
Installation Prefix:
/usr
Settings folder:
/home/geir/.audacity-data
Core Libraries
wxWidgets
(Cross-platform GUI library)
3.1.5
PortAudio
(Audio playback and recording)
v19
libsoxr
(Sample rate conversion)
Enabled
File Format Support
libmad
(MP3 Importing)
Enabled
libvorbis
(Ogg Vorbis Import and Export)
Enabled
libid3tag
(ID3 tag support)
Enabled
libflac
(FLAC import and export)
Enabled
libtwolame
(MP2 export)
Enabled
QuickTime
(Import via QuickTime)
Disabled
ffmpeg
(FFmpeg Import/Export)
Disabled
gstreamer
(Import via GStreamer)
Disabled
Features
Theme
(Dark Theme Extras)
Disabled
Nyquist
(Plug-in support)
Enabled
LADSPA
(Plug-in support)
Enabled
Vamp
(Plug-in support)
Enabled
Audio Units
(Plug-in support)
Disabled
VST
(Plug-in support)
Enabled
LV2
(Plug-in support)
Enabled
PortMixer
(Sound card mixer support)
Enabled
SoundTouch
(Pitch and Tempo Change support)
Enabled
SBSMS
(Extreme Pitch and Tempo Change support)
Enabled
The problem is that I’m not able to import the audio successfully. I don’t get any error messages, but the resulting audio track does not seems to include any actual data - but get a length.
Things I’ve tried out / is done
- Tried different text encoding, including unicode and west european (but in limited number of attempts)
- Different line endings, both Windows and Linux line endings are tested, same result (use Geany for this and last point)
- Tried to replace all numbers to force 5 decimal places (just a random thing I did because I saw another forum thread where OP had used 5 decimals).
I don’t understand if there is something I do wrong here? I expect to see a wave curve (probably not pretty), but get nothing.
IA.txt (5.31 KB)
