Audacity: error whem using Ctrl+Shift+I shortcut in manjaro linux [SOLVED]
Please state:
Creto
Post by Creto » Fri May 14, 2021 3:01 pm
Hello all,
I have this problem in audacity whenever I import a song for editing with the “Ctrl+Shift+I” shortcut
https://postimg.cc/Y4Tz8wQr
https://postimg.cc/G4HMjK6j
Well put the file "error" on my google drive
error shortcut | g-drive Creto
I appreciate suggestions, thank’s!
I'm brazillian user, sorry my bad english (google translate)
Manjaro release:
Code: Select all
lsb_release -a                                                   ✔
LSB Version:    n/a
Distributor ID: ManjaroLinux
Description:    Manjaro Linux
Release:        21.0.4
Codename:       Ornara
Audacity version:
Code: Select all
audacity --version                                               ✔
Audacity v2.4.1
T+ = See you later
Re: Audacity: error whem using Ctrl+Shift+I shortcut in manjaro linux
Post by steve » Fri May 14, 2021 3:12 pm
When precisely does the error occur? Does the error message pop up immediately after pressing "Ctrl + Shift + i"?
Does the error occur with any other keyboard shortcuts?
audacity --version
Audacity v2.4.1
How did you install Audacity?
This page says that the Manjaro version of Audacity is 2.3.3
https://discover.manjaro.org/applications/audacity
Creto
Post by Creto » Fri May 14, 2021 4:06 pm
Hi steve,
Despite using audacity for a long time, I don't know of other shortcuts, being the only one that uses the same as the topic title, or Ctrl+Shift+I
I think the version informed by discover manjaro is wrong, as I can show you below:
Code: Select all
 pamac search audacity                                            ✔
darkaudacity-git                            2.1.3.r1237.gec4838600-1  AUR
    A program that lets you manipulate
    digital audio waveforms
audacity-wxgtk2                             3.0.2-1                   AUR
    Record and edit audio files
audacity-git                                2.4.2.r0.g16d52f63a-2     AUR
audacity-alien                              3.0.2-1                   AUR
    digital audio waveforms (patched
    version from Alien Bob repo due to
    upstream packaging issues)
audacity                        [Instalado] 1:2.4.1-4                 community
With that I will also show the command to reinstall audacity
Code: Select all
pamac reinstall audacity                                         ✔
Preparando...
Aviso: audacity-1:2.4.1-4 está atualizado -- reinstalando
Resolvendo dependências...
Verificando conflito entre pacotes...
Para reinstalar (1):
  audacity  1:2.4.1-4    community
Aplicar transação ? [s/N]
Thank's for your answer!
T+ = See you later
Creto
Post by Creto » Fri May 14, 2021 4:12 pm
Hi steve,
Code: Select all
Code: Select all
Preparando...
T+ = See you later
Post by steve » Fri May 14, 2021 4:31 pm
Can you try "audacity-wxgtk2 3.0.2-1"?
Creto
Post by Creto » Sat May 15, 2021 12:04 am
I uninstalled 2.4 and I'm compiling this one, but on my powerful computer (laughs) it will take a while when I'm done, I'll be back here thanks Steve
T+ = See you later
Creto
Re: Audacity: error whem using Ctrl+Shift+I shortcut in manjaro linux [SOLVED]
Post by Creto » Sat May 15, 2021 1:25 am
Hi steve,
Audacity 3.0.2 AUR version installed and working well, thank you very much for your collaboration steve
>> Audacity 3.0.2 in manjaro Linux | Solved <<
T+ = See you later
Post by steve » Sat May 15, 2021 11:37 am
Thanks for the update.
I'll close this topic as solved so that the solution is easier for others to find.
