Plug-in Not Listed in Menu
Please state:
flood
Post by flood » Wed May 05, 2021 11:29 pm
Hi all, new to Audacity and ran across an easy problem!
I want to use the pseudo stereo plug-in. It just isn't listed in the effects (or other) menu after I enable it.
I have followed the install instructions and put the Pseudostereo.ny file in /usr/share/audacity/plug-ins folder
I have enabled it in the audacity application (Effect / Add remove plugin)
It doesn't show up under any menus. I am trying to add stereo effect to a mono recording.
My Info:
5.4.0-72-generic #80-Ubuntu
Audacity 2.3.3
Installed via apt-get
;nyquist plug-in
;version 3
;type process
;categories "http://lv2plug.in/ns/lv2core/#SpatialPlugin"
;name "Pseudo-Stereo..."
Re: Plug-in Not Listed in Menu
Post by steve » Thu May 06, 2021 10:25 am
Make sure that you are looking in the right place. It should be in the "Effect" menu, down in the bottom sections below the dividing line.
flood
Post by flood » Thu May 06, 2021 11:44 pm
Ah ha!!!
I didn't even bother to look in those sub menus below the dividing line. Thanks for your help!
Post by steve » Fri May 07, 2021 12:06 am
Just for your information, there are a few options for how effects are listed: https://manual.audacityteam.org/man/eff ... ences.html
(Most Audacity users, including myself, use the defaults)
