launch error in Raspberry Pi
Please state:
djsg
Post by djsg » Mon Apr 05, 2021 5:04 am
I built Audacity from source code in Raspberry Pi 4.
Here are some info about the build:
wxWidgets-3.0.5
sudo apt-get install gtk+2.0
../configure --with-gtk
make
sudo make install
sudo ldconfig
audacity
cd audacity-minsrc-2.2.2-rc1/
mkdir build
cd build/
../configure -with-lib-preference="local system" --disable-sse
make
./audacity
I tried to launch audacity from the build folder, got the following error:
[email protected]:~/Downloads/audacity-minsrc-2.2.2-rc1/build $ ./audacity
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
(audacity:2400): GLib-GObject-WARNING **: 10:55:26.332: ../../../gobject/gsignal.c:2641: instance '0x19d3d00' has no handler with id '143'
(audacity:2400): GLib-GObject-WARNING **: 10:55:26.336: ../../../gobject/gsignal.c:2641: instance '0x19d3800' has no handler with id '98'
double free or corruption (out)
Aborted
Before it crashed, audacity created some files in folder /tmp/Audacity_dbgrpt-2400-20210405T105503.
I update those files in the attachment.
BTW, there is an working audacity in the system, which was installed with apt command and same version.
audacity.cfg
(98 Bytes) Downloaded 149 times
Audacity.xml
(38.08 KiB) Downloaded 192 times
log.txt
(132 Bytes) Downloaded 164 times
pluginregistry.cfg
(40.79 KiB) Downloaded 167 times
