I’ve recently installed Audacity 3.0.0 following the wiki (https://wiki.audacityteam.org/wiki/Building_On_Linux) on Linux Mint 20.1 Ulyssa.
I’ve noticed i don’t have Click track whereas in an old packaged version I had.
Silly me noticed, it’s a plugin that needs to be enabled.
Now, when i enable it, nothing happens, it doesn’t get into the menu.
I tried it with other plugins, and they don’t appear in the menu either, regardless of being enabled.
Unfortunately I tried to remove everything from the menu, to see if I can add them back, and as above, they didn’t appear either.
Now i have an empty Generate menu.
Restarting Audacity doesn’t help.
Any workarounds?
(the files exist in the referred paths)
thx four your answer.
However, i don’t have that hidden folder in my home, i guess because i built it from source (?)
I renamed those 3 files in ~/audacity-minsrc-3.0.0/build/bin/Release/Portable Settings/, and indeed the startup looks fresh.
What it only achieved though, is that now the Generate - Add/Remove Plugins menu doesn’t show the plugins that are referred to with a path, only those that are built-in.
thank you, installation solved everything.
Apparently i was too happy see it running after the “4. Testing the build” point, I forgot to continue to read the instructions.
