Hi,
I recently installed Audacity on my system (Linux Mint 20.2 Cinnamon)
juillet@juillet-K73SJ:~$ apt-cache policy audacity
audacity:
Installé : 2.3.3-1build1
Candidat : 2.3.3-1build1
Table de version :
*** 2.3.3-1build1 500
500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
100 /var/lib/dpkg/status
but the app is not working; the command sends me back:
juillet@juillet-K73SJ:~$ audacity
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:869:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = Aucun fichier ou dossier de ce type
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
16:13:14: Debug: ScreenToClient cannot work when toplevel window is not shown
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1736
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1904
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2171
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2839
ALSA lib pcm_dsnoop.c:641:(snd_pcm_dsnoop_open) unable to open slave
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4628
16:13:21: Debug: ScreenToClient cannot work when toplevel window is not shown
16:13:21: Debug: ClientToScreen cannot work when toplevel window is not shown
16:13:21: Debug: Unrecognized accel key 'backspace', accel string ignored.
16:13:21: Debug: Unrecognized accel key 'numpad_enter', accel string ignored.
An Audacity icon opens in the taskbar. From this icon you can open Audacity in full screen, but the application is not functional. No action possible and impossible to close the application.
Where is the problem ?
