Hi
So I know that Steve helped me before.
Previously I had 2.4.2 running before. It was a strange situation where it would only work from within the version I had downloaded and put into downloads. I could not install and run as per every other piece of software on my Linux 19.3 machine.
I have uninstalled it in anticipation of putting 3.0.0 on. When I go to add the PPA, that just seems to take me to links for 2.4.2. No 3.0.0. Fine I think, I’ll just put 2.4.2 back on. So I go back to either Synaptic or Software Manager or Terminal and everytime I try and put the old version back on, it refuses to work and gives me errors so basically I no longer have access to Audacity. Is there anything I can try as I rely on this daily and am going to have to go back into Windows until I get this sorted.
Thank you.
EDIT: If I run from Audacity from Terminal, this is the error I now get
audacity: error while loading shared libraries: libwx_gtk2u_html-3.1.so: cannot open shared object file: No such file or directory
but it was working until an hour ago - I have no idea how to fix this error.
