Hello! Thank you for the Audacity, but there is some problem.
I worked fine about a month. Then soft was updated.
- Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
- Audacity 2.3.3
- Installed through mintinstall program manager. I worked fine about a month. Than soft was updated by command:
sudo apt install audacity
Чтение списков пакетов… Готово
Построение дерева зависимостей
Чтение информации о состоянии… Готово
Уже установлен пакет audacity самой новой версии (2.3.3-1build1).
Следующие пакеты устанавливались автоматически и больше не требуются:
libllvm10 libu2f-udev linux-headers-5.4.0-40 linux-headers-5.4.0-40-generic
linux-headers-5.4.0-48 linux-headers-5.4.0-48-generic linux-headers-5.4.0-51
linux-headers-5.4.0-51-generic linux-image-5.4.0-40-generic
linux-image-5.4.0-48-generic linux-image-5.4.0-51-generic
linux-modules-5.4.0-40-generic linux-modules-5.4.0-48-generic
linux-modules-5.4.0-51-generic linux-modules-extra-5.4.0-40-generic
linux-modules-extra-5.4.0-48-generic linux-modules-extra-5.4.0-51-generic
I have got this each time when I record new audio. It happens when I’m trying to read my text in the same time and in the same paragraph.
An assertion failed!
ASSERT INFO:
…/src/common/wincmn.cpp(1044): assert “(minW == wxDefaultCoord || maxW == wxDefaultCoord || minW <= maxW) && (minH == wxDefaultCoord || maxH == wxDefaultCoord || minH <= maxH)” failed in DoSetSizeHints(): min width/height must be less than max width/height!
BACKTRACE:
[1] wxWindowBase::DoSetSizeHints(int, int, int, int, int, int)
[2] wxTopLevelWindowGTK::DoSetSizeHints(int, int, int, int, int, int)
[3] ProjectWindow::UpdateLayout()
[4] wxEvtHandler::TryHereOnly(wxEvent&)
[5] wxEvtHandler::ProcessEventLocally(wxEvent&)
[6] wxEvtHandler::ProcessEvent(wxEvent&)
[7] wxEvtHandler::ProcessPendingEvents()
[8] wxAppConsoleBase::ProcessPendingEvents()
[9] wxApp::DoIdle()
[10] g_main_context_dispatch
[11] g_main_loop_run
[12] gtk_main
[13] wxGUIEventLoop::DoRun()
[14] wxEventLoopBase::Run()
[15] wxAppConsoleBase::MainLoop()
[16] wxEntry(int&, wchar_t**)
[17] main
[18] __libc_start_main
[19] _start
Please give me some advice how to fix this.
