Audacity closes when I stop an audio on my raspberry pi 4.
Please state:
pafb8
Operating System: GNU/Linux other
Post by pafb8 » Tue Jul 14, 2020 12:48 pm
Hello (firstly, sorry for my bad english). I'm running raspbian on my raspberry pi 4, and I use the version of Audacity 2.2.2 but the other day it stoped working correctly. Now, when I play an audio and then I stop it or when it ends, instantly Audacity closes. It's probably a silly mistake, but I don't know what to do.
If someone could help me It would be awesome.
Re: Audacity closes when I stop an audio on my raspberry pi 4.
Post by steve » Tue Jul 14, 2020 1:06 pm
Although we have reports that Audacity can run on Raspberry Pi, we do not officially support those devices.
If you were previously using default settings in Audacity, you can go back to those "factory defaults" by deleting the three files:
~/.audacity-data/audacity.cfg
~/.audacity-data/pluginregistry.cfg
~/.audacity-data/pluginsettings.cfg
("~/" is your Home directory)
pafb8
Post by pafb8 » Wed Jul 15, 2020 9:35 pm
I've tried, but it doesn't work
