Audacity don't launch : Mismatch between the program and library build versions detected.
Please state:
Dirky
Operating System: Linux Debian
Post by Dirky » Thu Jun 04, 2020 5:28 pm
Hello,
I have another problem with audacity : when i try to launch it, i have this error :
The library used 3.0 (wchar_t,compiler with C++ ABI 1013,wx containers,compatible with 2.8),
and your program used 3.0 (wchar_t,compiler with C++ ABI 1011,wx containers,compatible with 2.8).
Abandon
I have tried to reinstall wxwidgets with apt, but didn't work. Can you help me please ? I'm on Debian 10.
Thanks !
EDIT : I use Audacity from the Debian 10 repository
Re: Audacity don't launch : Mismatch between the program and library build versions detected.
Post by steve » Fri Jun 05, 2020 12:44 am
I've just tried installing Audacity 2.2.2 from the Debian repository onto a clean install of Debian 10.4, and it works fine.
