Unable to Use Line as Input to Audacity
Please state:
hobohro
Post by hobohro » Thu May 07, 2020 6:35 pm
I have been unable to configure or use the line output from the computer as input to Audacity. Microphone does work.
host=ALSA Using = PortAudio v19.5.0-devel. Any suggestions?
Running 18.04 Ubuntu at latest patch level.
Audacity = 2.3.3
hobohro
Re: Unable to Use Line as Input to Audacity
Post by hobohro » Fri May 08, 2020 4:50 pm
I found the problem. The pavucontrol recording tab asla plug-in was MUTED! :oops:
