I have verified that no other running audio devices etc were running...
ISSUE
If I hit record, the the cursor/line on timeline travels very slow, where it take 10 seconds to reach the 1 second marker! Inputs work and records data to timeline which results then of sound 10x to fast! Multiple builds test 2.3.3-2.4.0-alpha
So a bizarre issue indeed.. stay tuned.
Old hardware with same exact system OS specs was a 15-year old pentium dual-core with 4G - no problems.
New hardware with same exact system OS specs is a fast i7 cpu with 32G ram, high-end, etc - problems.
Same issue occurred before rebuilding clean to 2.4.0 today.
ISSUE
Brutal flaw, rendering recording busted.
Sidenote: previous issues fro, 2.3.3 you might want to call for testing reports:
- Audacity still crashes periodically especially if you have rough 2 hours of audio via 20 tracks (for a firm example). This happens I assume as some processing from basic editing or cursor movement is still active when user clicks around. I thought this was due to older antiquated system but it's not as my system tested recently is ultra-top end and powered. Linux builds - I know this happens on Arch and CentOS.
